Creaky steering wheel. . .
Discussion in 'Gen 2 Prius Main Forum' started by Fubar1764, Nov 19, 2012.
  1. Fubar1764
    Fubar1764 Member
    127
    Houston, TX
    I doubt if this is part of the recall. Anyone have any thoughts on a creaky steering wheel? At any point in the steering, it creaks when turned. The creaking sounds like the flexing and bending of wood a la creaking wooden floors. Thoughts?
  2. Britprius
    Britprius Senior Member
    5,194
    1,918
    Herefordshire England
    The best I can offer is that you return the car to the dealer for the recall and if there is a problem it should be fixed at no charge.
  3. elec1
    elec1 Junior Member
    pa
    Check the connection between the steering column and the rack. Remove the boot where the shaft goes threw the firewall next to the gas pedal.There's a short piece that connects with two bolts on top and two on bottom. My problem was where the splines go into the shaft, broke loose, took it off and had it spot welded. Hope this helps. easy fix
  4. Britprius
    5,194
    1,918
    The steering shaft is part of the latest recall.
  5. goddess prii
    goddess prii Member
    63
    50
    Atlanta, GA burbs
    I have the same problem. Today I took it to the dealership. They could not duplicate the noise. They did lubericate the area. If the problem persists, I am to take it back. Welllllllll....... guess what? It is still making the same noise. So, I gues I will take it back later in the month.:( The noise I hear sounds like a clicking sound.
