Cruise Control Problems?
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by bwilson4web, Feb 19, 2010.
  1. Yes - I've had this happen (please add details)
    0 vote(s)
    0.0%
  2. No - never seen it
    92.3%
  3. Something else - please provide details
    7.7%
  1. bwilson4web
    15,933
    A user reported this symptom with their cruise control:
    Has anyone else seen this symptom?
    This is not the Woz problem of incrementing and decrementing speed and having a delayed application of these change requests at one time.
    RECOMMENDATION
    If possible, perhaps you could drive to a dealer service center with the problem and keep them from turning off the car. Have their service technician or staff confirm the problem. In theory, they should be able to plug in their diagnostic system and capture 'live data' from the problem.
    The cruise control consists of:
    • set of resistors in series within the stalk assembly
    • stalk switches that tap different parts of the resistor network
    • wiring harness
    • control computer line that reads the resistance values
    If I were trying to diagnose the problem, the first step would be to read the resistor network values and look for noisy contacts. If the values are marginal, swap the stalk. But having the problem clear by power-cycling the car points towards the control computer.
    All I can do is suggest that every time it fails, write your notes including as many environmental conditions as possible (aka., time, weather, miles or time before failure, internal temperature setting) and when you get back, make a service call at the dealer. This also establishes a rate. What this does is make a formal log so the dealer has backup to justify 'parts swapping' and escalation.
    Eventually, it becomes time to escalate the problem to their next service level. It is a negotiable point to work with the dealer.
    It would be nice if we could move this sub-discussion to Maintenance.
  2. Tom183
    Tom183 New Member
    652
    65
    Maine
    I have had an issue where the cruise is set, and I use the gas pedal to accelerate temporarily, then when I lift off it's like the cruise forgets where it was set and just drops down way below where it had been - even though the "set" light is still on.
    Also (maybe this is by design), whenever I shut off the car, the cruise switches off - next time I start, it has to be turned on again. annoying.
  3. bwilson4web
    15,933
    I may have seen that but I need to retest.
    If the car drops below 23 mph, it forgets all settings. I wish it would go as low as 10 mph for some of my engineering studies.
  4. vday
    vday Member
    312
    Israel
    Is it possible that the gear shift is in B rather then D
    It happened to me a few times
  5. glenmcafee
    glenmcafee New Member
    Northfield, MN
    Happened to me last night. I have owned my 2010 Prius for two days and it wouldn't engage the cruise control. However, when i restarted this morning, the symptom was gone and all was well. Have you found a solution yet?
  6. Armywife
    Armywife New Member
    32
    Fort Knox
    All cars that I have owned did that, any change in speed, acceleration or braking would turn off the Cruise Control even if the light still said set. A Blazer, Optima and the Prius. I thought that was just how it was...
  7. glenmcafee
    Northfield, MN
    Thanks to the suggestion from vday, I determined that if I had downshifted using 'B', the Prius stays in 'B' even though it operates normally and you thinkyou're in 'D'. So, simply popping the gear back to 'D' worked and I was able to engage Cruise Control.
  8. Martin37
    Martin37 New Member
    200
    23
    Joseph, Oregon
    Cruise control does NOT work in B!
