1. Cynthia Schneider
    Cynthia Schneider New Member
    Lincoln, CA
    My OBD scanner indicates a cylinder misfire. I had the spark plugs and coils replaced but the check engine light still comes on intermittently. The scanner still shows engine misfire. Does anyone have any suggestions? Thanks
    50,861
    how many milres? loding any coolant? have you cleaned the egr circuit? might be head gasket
    Mendel Leisk and tankyuong like this.
  3. Mendel Leisk
    40,288
    ^ Rearranging deck chairs on the Titanic.
    Which cylinder is the misfire code indicating? One and/or two are the usual culprits.
  4. CR94
    CR94 Senior Member
    2,660
    1,148
    Northwestern S.C.
    Mileage on the car?
  5. Cynthia Schneider
    Lincoln, CA
    4 is misfiring- there's 180 thousand miles on it!
  6. bisco
    50,861
