Dash rattle found!
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by afternoonnap, Mar 16, 2006.
  1. afternoonnap
    afternoonnap New Member
    33
    Ontario, Canada
    Thanks to Frank Hudon's tip in another thread about listening through a hose to find a rattle, we found our Prius' annoying dash rattle! It was coming from the windshield side of the front center speaker.
    I know the front speaker is common culprit for dash rattles, but pressing down on ours never stopped the rattle. So I thought it must be something else. The rattle was worse on bumpy roads in colder weather.
    In our case the rattle seemed to be coming from the soft white clip holding the cream-colored connector to the black speaker grill, where they were attached. Perhaps I introduced some play in the joint when I disconnected the speaker several months ago. Now it's a loose connection between the two light-colored plastic pieces, but I haven't figured out how to get them apart yet.
    Not sure what to do out of the following choices:
    - Wedge something in the joint to take out the "play" and put the speaker back in (still disconnected)
    - Unscrew the speaker from the grille, and just put the grille back in.
    - Get the clip seperated from the connector somehow, and put speaker back in without the rattling clip.
  2. V8Cobrakid
    V8Cobrakid Green Handyman
    3,790
    152
    My center speaker rattles too. I have taken it in and out of it's spot any times. It gets looser and looser each time. I'm going to do what i did to my doors. Put a strip of insulation tape around the edges and put it back into place. It cured my door rattles (caused by audio bass...er... lack there of in a way).
    I need to get a hose from work and do this rattle test myself. I know my rear driver door tweeter rattles too.. (shrug) i'lll have to take the door apart for that one.
  3. afternoonnap
    33
    Ontario, Canada
    Just to clarify, in my case it wasn't where the speaker fit in the dash that rattled. Rather it was the bit that holds the wire connector to the windshield-side edge of the speaker grill.
    Next time you've got your center speaker out (mine's been out and back many times too) try wiggling the connector to see if it could explain your rattle.
    I've also had rattles that disappeared when I opened and closed the cup holders, or that happened when the drawer at the bottom of the console wasn't fully shut.
    BTW, the hose we used was left over from a dishwasher installation. Otherwise I would have bought a short length of clear tubing.
    If your rattle goes away with the speaker out, then you won't learn much more from listening through a tube. :)
  4. V8Cobrakid
    3,790
    152
    hehe.. thanks.
  5. hdrygas
    hdrygas New Member
    3,650
    Olympia Wa
    Great tip. A lot of Techs will help you out and will take suggestions, if you say, I have heard that some one else had this problem could you please check that out? Or could that be the problem? Mostly people will respond to gentle nudging.
