Dashboard warning lights on
Discussion in 'Newbie Forum' started by David Amato, Feb 5, 2018.
  1. David Amato
    David Amato New Member
    Tallahassee, FL
    I have a 2008 prius with about 122,000 miles.
    All my warning lights on the dash board are on: ABS, VSC, checjk engine, tire pressure sensors, BRAKE, exclamation point inside circle.
    Also, gas mileage has dropped from 51 mph to 43 mph.
    Also, sometimes when starting the prius i get a constant high pitched beep for around 5 or 6 seconds.
    Is my traction battery dying?
    50,846
    welcome!
    not necessarily. best to read the codes and post back here for help. the high pitched beep may be indicating a brake issue.
    Mendel Leisk and Raytheeagle like this.
  3. David Amato
    Tallahassee, FL
  4. David Amato
    Tallahassee, FL
    The codes are P1121 and P1116. These have to do with the coolant control valve and coolant temperature sensor.
  5. RCO
    RCO Senior Member
    3,709
    5,185
    Cornwall
    Welcome to Prius Chat David. Sorry I can't help you out with the codes, but someone will pitch in before long with advice.
  6. bisco
    50,846
    then there's your problem, battery is fine.
    RCO and Raytheeagle like this.
  7. ericbecky
    ericbecky Hybrid Battery Hero
    4,381
    3,242
    Madison, Wisconsin
    Codes have helped point you in the right direction.
    Now you just need to fix those issues.
