Daytime running lights
Discussion in 'Gen 2 Prius Technical Discussion' started by jtfleischer, Dec 19, 2006.
  1. jtfleischer
    jtfleischer JTFleischer
    Birdsboro, Pa
    Does anyone know if you install the 7.5Amp fuse in the fuse box under the hood will this activate the daytime running lights? The manual shows the position for the daytime running lights fuse just above the headlight fuses.
  2. seasalsa
    seasalsa Active Member
    1,278
    Kent, WA
    <div class='quotetop'>QUOTE(jtfleischer @ Dec 19 2006, 06:59 PM) [snapback]364409[/snapback]</div>
    Not in the USA, Canada has DRL but all we get is Auto Off.
  3. YoDaddyAlex
    YoDaddyAlex Member
    271
    thats really too bad about no DRL in the US. the manual should at least note that when describing the "auto" headlight feature, I noticed I didn't have that option and was going to run to the dealer to complain about why it wasn't in!
  4. seasalsa
    1,278
    Kent, WA
    <div class='quotetop'>QUOTE(YodaddyAlex @ Dec 20 2006, 08:45 AM) [snapback]364628[/snapback]</div>
    The manual has a disclaimer stating that all options might not be included on your vehicle. I believe the owners manual is for North America not just the US.
  5. DanMan32
    DanMan32 Senior Member
    3,799
    27
    Tampa Bay, FL
    You may find a space reserved for the fuse, but you won't find any electrical connections there.
    Also missing are relays and other wiring. And DRL was not made compatable with HID, which is why Canadian market aren't offered HID.
  6. larry55
    larry55 Junior Member
    <div class='quotetop'>QUOTE(DanMan32 @ Dec 30 2006, 04:58 PM) [snapback]368703[/snapback]</div>
    I am new to the forum and just bought a 2007 Prius Friday. Have been going over the manual and am disappointed there is no daytime running lights. This should be a basic safety feature on all new cars. Is there a workaround for this? Does anyone have any ideas on this. Would appreciate some brainstorming on a way to get us daytime running lights.
    Thanks
  7. seasalsa
    1,278
    Kent, WA
    I use the Auto Off feature, if you leave your lights on they will shut off Automatically when you power off and open the drivers door.
  8. Tideland Prius
    16,401
    You can either leave your headlights in the ON position (It has auto-off so it'll shut off if you open the driver's door) or get a DRL kit and use the foglights or turn signals as DRLs
  9. prius2go
    prius2go Member
    312
    I thought daytime running lights had been shown to increase overall accident rates since pedestrians and cyclists are relatively less visible?
  10. David Beale
    David Beale Senior Member
    5,963
    1,985
    Edmonton Alberta
    How would pedestrians and cyclists be less visible with DRLs? Bicycle reflectors will light up even in daylight. Pedestrian reflective clothing will also light up. DRLs are no replacement for headlamps at dusk and dawn (or at night). They are "DAYTIME RUNNING LIGHTS".
    All the studies I've seen showed about 10-15% drop in accidents. I haven't seen a recent one though.
    Be aware, there are some shortcomings with DRLs. For example, the tail lamps are off.
    The headlamps are run at lower intensity. The parking brake is supposed to shut them off, if you are stopped with the engine running (old term - in ready mode with the Prius). There are quite a few vehicles that use turn signals for DRLs (Chryslers, particularly the minivans, RX-7s, many vehicles with fold-down headlamps, and some HID equipped vehicles).
    You can purchase a DRL module and connect it as you please in the US. It isn't illegal to have the parking lights or turn signals on as DRLs there. Here it has to be approved to fulfill legal DRL function.
    DRL modules available from places such as:
    http://www.hamsar.com/drlkits.htm
  11. hill
    8,560
    <div class='quotetop'>QUOTE(prius2go @ Aug 13 2007, 05:22 AM) [snapback]494596[/snapback]</div>
    NO ~ Studies actually show it's a mixed bag ... some saying yes & others contradict ... certainly NOT the overwhelming big winner that was originally predicted.
  12. prius2go
    prius2go Member
    312
    <div class='quotetop'>QUOTE(David Beale @ Aug 13 2007, 05:19 PM) [snapback]494727[/snapback]</div>
    :D
    there's always one that misreads
    imagine youre old decrepid and driving a beat up station wagon
    the vehicles coming towards you are more visible because they have DRLs
    but you dont see the things without DRLs that you would previously have seen
    pedestrians, cyclists, animals, vehicles without DRLs, etc
    to equalise - pass a law to make pedestrians and Cyclists have DRLs too
    and we're back to where we started
    someone will then campaign for brighter DRLs B)
    It's one of these safety measures which has unforseen consequences with a result of not improving safety
  13. kohnen
    kohnen Grumpy, Cranky Senior Member
    317
    58
    Fullerton CA
    <div class='quotetop'>QUOTE(prius2go @ Aug 13 2007, 04:22 AM) [snapback]494596[/snapback]</div>
    So we should legislate that cyclists and pedestrians also have DRLs!
    Seriously, let me know your thoughts on this idea:
    1) Remove the 9006 bulbs in the fog lights.
    2) Replace them with HID bulbs designed to replace the 9006 bulbs.
    3) Wire them in so that the fog lights are on whenever the Prius is in the READY mode and the headlight are off.
    That way, you get long-lasting DRLs, and they get shut off when the real headlights are on.
    Or, simply change the wiring so that the 9006 fog lamps are hooked up in series whenever READY is on and the headlights are off.
    Thoughts? Ideas?
  14. David Beale
    5,963
    1,985
    Edmonton Alberta
    Fog/driving lights on without headlamps on is illegal in the US and Canada. Lots of people get ticketed for it (it's a popular modification to most new cars).
    Turn signals or "parking lights" on while driving is not illegal. Hence, they are used. You'd be surprised how bright they are.
  15. CinciPrius
    CinciPrius Member
    110
    Cincinnati
    <div class='quotetop'>QUOTE(Gussack @ Aug 12 2007, 10:51 PM) [snapback]494479[/snapback]</div>
    I've added turn signal based DRLs to my 2005 Prius and have been very happy with the results. I like the yellow DRL effect much better than the often glaring high beam DRLs.
    I got the DRL kit from Web Electric Products. The installation is very simple. I've attached a Word document that shows the specific wires you need to connect to on the Prius.
    Here's a link to a file that I uploaded showing how to hook up the module on the Prius.
    Alan
  16. Tideland Prius
    16,401
    <div class='quotetop'>QUOTE(David Beale @ Aug 13 2007, 09:19 AM) [snapback]494727[/snapback]</div>
    Yeah.. esp. those people not used to electronic gauges. Those things are "on" whether the lights are on or not and at night when the DRLs are on, they think their headlights are on (even though there's a big difference in intensity btwn DRLs and low beams. Some people are just clueles...
    <div class='quotetop'>QUOTE(prius2go @ Aug 13 2007, 09:30 AM) [snapback]494734[/snapback]</div>
    No need. The Jeep Grand Cherokee has hella bright DRLs.. I swear Chrysler didn't aim it properly or something; that or they're at full intensity and not reduced. Anyone who's seen a new Grand Cherokee with DRLs will know what I mean. Even in bright sunshine, they look as if the driver has the high beams on.
    <div class='quotetop'>QUOTE(David Beale @ Aug 13 2007, 12:16 PM) [snapback]494859[/snapback]</div>
    Remember how I said the Murano, A4 etc have foglights as DRLs?... they're from the factory as well.
  17. ATX
    ATX New Member
    Austin, TX
    didn't do a thing on my '04.
  18. prius4ed
    prius4ed Member
    120
    Irvine, CA
    how to connect fog lights to a Gen 2 Prius that didn't have foglights
    My 2004 Prius didn't come with foglights. I installed OEM foglights (each uses a 9006 55watt headlight bulb), and need to wire them up. Anyone know the easiest way to connect them (I don't need a switch inside the cabin) so that they're on whenever the car is "running"? Someone here used the washer pump blue wire, I think, because I guess it's "hot" when the car is "running". Is a relay needed? With two 9006 55watt bulbs in the foglights, we're flowing about 9.2 amps total. I have a feeling the washer pump circuit and wiring won't be enough for 9.2 amps continuous current.
  19. Bababooey
    Bababooey Horse Toothed Jackass
    48
    Nassau County, NY
    I believe that you are mistaken about "fog/driving lights on without headlamps on is illegal in the US". I own a 2010 Chevy Camaro SS with the optional RS package, and the fog lights function only as Daytime Running Lights. The car's HID headlamps only come on at night, at which time the DRLs turn off.
  20. ThePackage
    ThePackage New Member
    74
    I posted, a year ago, about a simple kit I purchased from www.webelectricproducts.com which turns the turn signals into DRL's. I chose the Synchronizing Mode. The install is very easy (even for a senior citizen) and all connections are under the hood. It has been working for over a year and I get compliments all the time from other Prius owners. The cost is under $50 which makes it very affordable. In terms of bulb life, I have yet to replace the turn signal bulbs after 15k of driving. And, of course, the turn signals work fine. No problems with NJ State Inspection.
