Dead Aux Battery - 05 - need troubleshooting advice
Discussion in 'Gen 2 Prius Main Forum' started by KCobby, Dec 1, 2010.
  1. KCobby
    KCobby Member
    229
    74
    NYC area
    Hi all,
    So, my aux batter - an Optima Yellow Top - has died. Yesterday when I went to go to work, the car didn't open using the SKS. No recognition of it at all so I entered with the key and pressed on: nothing. After holding it down, the car finally booted up, I got it started and off I went. Since work was about 1.5 drive, the battery was fully charged. I did NOT happen to notice what the voltage was on the scangauge when starting up, however. But obviously it was low enough so that it wouldn't start or boot up.
    I was nervous about leaving it at work for the day, but when I got back to the car in the late afternoon, everything worked as normal. Then, this morning, same thing: nothing. This time, the car wouldn't even give a HINT of being alive. It's currently sitting dead outside in the pouring rain.
    A little background: I think there is a short somewhere. I replaced the stereo, added an amp, etc. last year. Since then, I have noticed that sometimes I will get to the car and the clock was "off" and I have to reset it. Once, my ipod was left connected and when I turned the car off, the stereo that normally shuts it off did not and the ipod was completely drained as well. Which leads me to think that there is something wrong with the install, or that there is a short somewhere. The question is...
    How do I track it down?? I'm only slightly mechanically/electrically inclined. I can follow directions, but this seems a bit over my head. But, since I installed a stereo from directions on here...thought I would ask to see if any of you kind folks could help me troubleshoot this problem.
    Also, since my battery has been drained more than a couple of times, should I think about getting a new one??
    I'd like to avoid taking to the shop, but I'm not sure if I can diagnose this one. All help is greatly appreciated! Thanks!
    fwiw, the stereo sounds great! :D:rolleyes:
  2. Patrick Wong
    18,200
    6,490
    1. Hook up your 12V battery to a battery charger so that it can be recharged. Expect this process to take at least 8 hours. If the battery doesn't hold a charge then you will know that it needs to be replaced.
    2. You need a digital multimeter so that you can measure current draw when the car is IG-OFF. If you find that the current draw is more than 0.02 A or so, then you'll need to look for the cause by pulling fuses that provide power to likely culprits and seeing whether the current draw decreases markedly.
  3. KCobby
    KCobby Member
    229
    74
    NYC area
    Thanks Patrick - hard for me to hook up to a battery charger I think since I don't have an electrical outlet nearby. No garage for me (nyc) so it's in a parking spot. Maybe a portable one though? Am I correct in thinking that they make jumpers and chargers that are portable? (So then I'd have to charge that before charging the car?)
    I have a DMM - do I hook it up to the lead from the battery? Sorry, as I said, I'm a bit of a noob with the meter and electricity investigation.
  4. Patrick Wong
    18,200
    6,490
    Well, you will need an AC outlet for the battery charger. If that is not available at your parking garage then you will need to remove the 12V battery from the car, and carry it to a place where you can connect the battery charger.
    Once you have a known good battery, install it in the car. Turn off the two ceiling lights and the hatch light.
    Connect the DMM in series with the 12V battery negative terminal cable where it connects to the body. Do not turn the car IG-ON while the DMM is in series. Most DMM have a fuse that will blow if current flow exceeds 10A. Place the DMM where you can see it when the hatch is closed.
    Close the hatch and all doors. Keep the Smart fob 15 ft or more away from the car. Watch the current draw. After a few moments it should drop down to a stable value. See what that value is.
  5. Ryanpl
    Ryanpl Active Member
    780
    158
    Brooklyn, NY
    KC, by any chance are you downtown Brooklyn? If you are I can meet you and get you a jump start via my auto insurance roadside insurance.
  6. David Beale
    David Beale Senior Member
    5,963
    1,985
    Edmonton Alberta
    I'd measure the battery -first-. Directly. It may just be a poor connection to the car body at the -ve cable. Your first experience is what makes me think this. When you first tried to start it nothing happened. If the battery was truly dead, holding the start button down shouldn't make any difference. If there is poor contact in either battery terminal, slight loading may burn off some of the oxide and then it could provide enough to actually start the car (it doesn't take much, BTW). Also check the +ve terminal. Either could be either loose or corroded. Especially if you didn't clean them before connecting the battery when you first got it. The oxide is hard to see on lead terminals.
  7. KCobby
    KCobby Member
    229
    74
    NYC area
    Thanks guys. When (if) the rain stops here, I'll go out to check the battery and connections. Should I jump it first to get some charge and open the hatch? Or should I try to just get back there and take the battery out as Patrick suggested?
    Ryanpl - thanks for the offer...I'm in the Bronx. :(
  8. David Beale
    5,963
    1,985
    Edmonton Alberta
    Before charging it or removing it, I'd check the voltage directly across it. As I said, it may just be a connection issue. You can open the hatch from the outside if you connect a 12V source under the hood (as if you are going to boost it). If you do it this way you will -know- if the battery is actually dead. Then you can go from there. Or if you don't want to go through the hassle of getting 12V to connect to the boost terminal, crawl over the back seat, lift the floor cover and release the hood at the release lever (center of the hatch, just under the hatch door).
    You can purchase portable boosters. They contain a gel cell battery and charger (and often a light, air pump, etc). They don't cost a lot. You should be able to find one for $50 or less.
  9. KCobby
    KCobby Member
    229
    74
    NYC area
    David - thanks for the advice. I've had success!! Sort of...
    So I crawled in the back, released the hatch, and checked the battery across the terminals. Indeed, it read 12.5 volts! So I just wiggled the connections a bit and all of a sudden, the interior lights came on. Success! Sort of...
    I also tried to start up the car, but it didn't like that so much. It wouldn't start at first, and then started on the second attempt. But when it started up, it showed the "triangle of death" and threw some codes. The Scan Gauge gave two, and the computer on board gave one - here is what I wrote down:
    Scan Gauge codes: P0000 (those are zeros), and U0(zero)111
    Prius computer gave this on checking the LAN: EMV Code 01-DC, Sub Code 1C6-CB-1
    It also didn't seem to allow me to clear it. I haven't checked the codes online yet but I will.
    Any ideas outside of just cleaning the terminals???
  10. Patrick Wong
    18,200
    6,490
    Disconnect the negative battery terminal. Wait for 5 minutes to pass. While waiting, make sure that the positive battery terminal is tight.
    After the 5 min period, reconnect the negative battery terminal, making sure that both cable ends are secure.
    Then your car should be back to normal. You'll have the blinking fuel gauge for a few moments until the combination meter ECU figures out how much fuel is present. You'll have to reset the driver's window auto up/down and the radio presets. The trip odometers will be back to 0.
  11. northwichita
    481
    102
    29
    Wichita KS
    It sounds like you just had a bad connection. I've experienced this myself when I hand tightening the ground bolt when I needed to wrench it securely on a test drive after a fix requiring removing the voltage.
    Codes that don't clear after a battery disconnect should eventually clear with several on/off cycles, at least they do with me. I always have many error codes every startup after disconnecting the +12. I may not be something correctly though I did find cycling to IG-ON and off and then to READY mode helps..
  12. bang4abuckprius
    bang4abuckprius Junior Member
    Rocky Face, Georgia 30740
    I have dead 12 volt battery, what type battery can I put back in,
  13. okiebutnotfrommuskogee
    okiebutnotfrommuskogee Senior Member
    1,813
    Tulsa, OK
    Either one that you can buy from the dealer, or an Optima available on line from eLearnaid. I have the Optima. Not sure about the spelling of eLearnaid, but easy to find on google.
  14. David Beale
    5,963
    1,985
    Edmonton Alberta
    Do note that if the terminals were dirty/oxydized the battery charge level has probably dropped way down as it won't charge properly. So you should make sure the car is in "Ready" for several hours before shutting it off after you clean the terminals. It will take longer than that to fully charge the battery, but that should be enough to keep it going until you do get it fully charged (takes about 8 hours to fully charge a dead battery using the Prius in "Ready").
    I use a battery terminal cleaner, which you can purchase at most automotive stores for under $10. They have a round wire brush at one end (usually with a cover over it) and a post brush at the other. Use the post brush on the battery terminals to make them shiny, then use the round brush inside the cable ends to make them shiny on the inside. You push the cleaner over the posts and turn it several times to clean the post. Ditto for the cable ends. Very important even for new batteries. They come "pre-oxidized". ;)
  15. David Beale
    5,963
    1,985
    Edmonton Alberta
    You have two choices, a battery from the dealer or an Optima with cable adapters from elearnaid.com. They are about the same price.
    And I should learn to read all posts before answering, but saying it twice underlines it. ;)
