Dead battery
Discussion in 'Gen 2 Prius Technical Discussion' started by rajsid, Jan 12, 2010.
  1. rajsid
    rajsid New Member
    San Jose, California
    2002 Prius
    Looks like the battery on my 2003 Prius is drained. I may have left a light on last night.
    I have a few of questions.
    1) How do you jump start a Prius?
    2) If the battery is dead, what brand/type of battery is recommended?
    3) Is the car battery related to or connected to the drive train battery? Is there any chance that it's actually some problem with the large battery?
    Thanks
    ~R
  2. qbee42
    qbee42 My other car is a boat
    18,058
    3,076
    Northern Michigan
    1) Jump points under the hood as explained in your owner's manual. Alternately you can jump to the battery, but that requires you to crawl into the back and manually release the hatch.
    Be very, very careful to not reverse the polarity. Thousands of dollars worth of damage will occur instantly if you do.
    2) Yellow top Optima. Many other threads explain this in detail.
    3) No, and no.
    Tom
  3. jdenenberg
    jdenenberg EE Professor
    3,910
    1,908
    Trumbull, CT
    2020 Prius
    LE AWD-e
