Dead transmission at 88K miles
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by paco-shalom, May 20, 2013.
  1. paco-shalom
    paco-shalom Veteran Prius Owner
    62
    Phoenix
    I was driving a friend home yesterday, pulled to the curb to let her out, and the car stalled. It would not go back into READY mode, so I had it towed to my neighborhood Toyota dealer. This morning they ran the diagnostics and the results shocked me.
    Observed Fault Code:
    P0AA6-526,613- HYBRID BATTERY VOLTAGE ISOLATION FAULT
    Recommendation:
    REPLACE TRANSAXLE ASSEMBLY PER TSB 0306-08
    At a price tag of over $5K, I'm not sure it is worth paying for the repair. The car is a 2005 with just over 88K miles. Of course the extended warranty expired 4 months ago. Does the diagnosis above make sense and is this price for repair normal?
    Thanks in advance for any advice or other helpful information!
  2. css28
    css28 Senior Member
    1,566
    443
    Suburban Detroit
    It's a pretty rare repair. Your best bet would be to buy a used transaxle and have that swapped in.
    Per car-part.com you should be able to snag one for around $750.
  3. Britprius
    Britprius Senior Member
    5,194
    1,917
    Herefordshire England
    Just as a matter of interest have you had any work done on the air con system in the last few weeks. If so was it at the dealers or an independent shop. This can be relevant.
    John (Britprius)
  4. paco-shalom
    62
    Phoenix
    The only work done recently was the steering shaft recall, coolant flush, and oil/filter changes. The AC has never needed maintenance. So far all work has been done by the dealer.
    I've put in a call to a local shop that has served me well for other vehicles. We'll see what they quote for a transaxle replacement. Then I can get the Toyota dealer to clear the codes and I should be able to drive the Prius to the other shop.
  5. Britprius
    5,194
    1,917
    Thanks for the reply. The reason I asked is because this is not unusual when the wrong oil has been used in the AC.
    John (Britprius)
  6. css28
    css28 Senior Member
    1,566
    443
    Suburban Detroit
    How would the wrong AC oil affect the transaxle?
  7. Britprius
    5,194
    1,917
    It does not affect the transaxle but gives the HV battery isolation fault observed in the first post.
    John (Britprius)
  8. Patrick Wong
    18,200
    6,490
    The diagnosis makes sense, and as previously stated, you should look into the feasibility and cost of installing a used transaxle from a salvage yard.
    Regarding clearing the DTC, you can try disconnecting the negative battery cable where it bolts to the body for a few minutes. However if the high voltage fault is solid, then the DTC will come back and you still won't be able to drive the car.
  9. Britprius
    5,194
    1,917
    Are the MG's classed as part of the hybrid system in the US if so they would fall under the 8 year 100,000 mile guaranty or the carb state "if Phoenix is in a CARB state" guaranty of 10 years 150,000 miles.
    In the case of the 8year guarantee this may still be in force or just out it may be worth contacting Toyota to see if they will help.
    If Phoenix is in a CARB state it is under guaranty.
    John (Britprius)
  10. css28
    css28 Senior Member
    1,566
    443
    Suburban Detroit
    I think we've found that the transaxle (and all of its components) are not covered by the hybrid system warranty.
  11. paco-shalom
    62
    Phoenix
    Unfortunately Phoenix is not in a CARB state, so it's not covered under the TSB warranty extension either.
  12. Britprius
    5,194
    1,917
    I obviously take your word for this, but that does seem strange as MG' are required in the system to drive the car and charge the battery and as such are part of the system. In the UK/Europe the transaxle is part of the hybrid guaranty.
    John (Britprius)
  13. Patrick Wong
    18,200
    6,490
    In the US the transaxle (and the MGs within) is covered under the 5 year/60K mile powertrain warranty, not the 8 year/100K mile hybrid system warranty.
  14. Britprius
    5,194
    1,917
    What a getout!!!
    John (Britprius)
  15. 2k1Toaster
    6,035
    3,855
    Rocky Mountains
    Seems very strange for such a failure to happen. Has the ATF ever been replaced?
  16. paco-shalom
    62
    Phoenix
    I agree that this does not seem to be a common issue. There are many threads here that say ATF replacement is not necessary until at least 100K miles and maybe longer. Mine was replaced at 60K miles. I never experienced any issues prior to this sudden stop, so I would say it has something to do with the wiring or electronics. I hope to learn more before I spend a lot on repairs. I'm waiting for a call back from my favorite AAA approved shop.
  17. 2k1Toaster
    6,035
    3,855
    Rocky Mountains
    It can fail, but you would be in the extreme minority.
    Toyota says the ATF fluid does not need to be replaced. Ever.
    People on here suggest because of studies done on our dime sending out fluids for samples that you should replace it early to get the initial build shavings out (like 15K miles) and then every 30K after that. That is a conservative number. Changing every 60K is probably more "normal", but that initial clean is key.
    Just make sure your AAA shop knows Prii. The transaxle is not your average Ford's tranny and it will be unhappy if treated as such. For instance putting the wrong fluid in can cause isolation faults like you are seeing because the OE ATF WS fluid is specially non-conductive and some/most are conductive. Doesn't matter in a normal transmission, but in the Prius the fluid goes around the electromagnetics and you will get winding shorts.
  18. Britprius
    5,194
    1,917
    I seem to remember a post on PC where water had managed to enter the HV connector on the transmission causing this same problem.
    Has the car been driven through a lot of water or had the underside cleaned?
    Most MG faults are shorted windings rather than ground isolation faults. I would inspect the termination of the HV cables where they enter the transmission.
    I have not delved into this area yet, is it a water proof plug? or are the cables terminated under a cover?
    John (Britprius)
  19. Britprius
    5,194
    1,917
    Looking up fault code P0AA6-526,613 This can also be an inverter converter fault.
    Unless already done by the dealer, disconnecting and meggering the MG's should be the first step. They would need to be disconnected anyway if the transmission is proved to be faulty.
    John (Britprius)
  20. css28
    css28 Senior Member
    1,566
    443
    Suburban Detroit
    Meggering?
