Dealer Diagnosis 01 Prius
Discussion in 'Generation 1 Prius Discussion' started by colonel570, Jul 7, 2010.
  1. colonel570
    colonel570 New Member
    48
    Elon, NC
    2001 Prius
    Cox Toyota Burlington NC
    They want $600 to diagnose further:
    (The dealer gave me these codes and a bill for $95)
    P3000 12-123
    P3001 battery ecu
    P3009 voltage leak
    P3030 sense wire problem
    When I scanned the car with my OBD2 I could only find P3001
    Does this sound like a fair price or are they trying to cheat me?
    I am trying not to spend a fortune on this car, but its not looking good.
    2001 Prius 148k miles
    New HV battery 9 months ago from Toyota
    new inverter
    new battery ecu
  2. jk450
    jk450 New Member
    If you had a new HV battery installed nine months ago, the warranty (12 months, 12,000 miles) may still be in effect. Have you asked about this?
    Ignore P3000 for now. P3001 and P3030 together suggest loose or damaged voltage sensing wires. P3009 may or may not be related to the battery.
    Will the diagnostic fee be applied to labor for the repair?
  3. colonel570
    48
    Elon, NC
    2001 Prius
    I picked up the car and paid the bill. I will never use Cox Toyota in Burlington, NC again. Poor unhelpful service dept. BOO!
    I am selling the car as-is broken. I am sick of messing with it.
    $3000.00 as-is
  4. colonel570
    48
    Elon, NC
    2001 Prius
    Ok so I did'nt sell the car. (I was just mad)
    I took it to another Dealer (Rice Toyota) and they knew what was wrong with it before they took it in service.
    Aparently they have several Prius Master techs, and aren't complete idiots!
    They said they had just fixed one with the same problem. (power leads P3030)
    They said they thought the problem with my car was the power lead cables from the battery taking power to the rest of the car. I am waiting to hear more from them. (Does this sound plausible? or anyone know what part that is? im not sure)
    They said the other one in service was $575.00 to fix it, plus they put a new battery in the other one at the owners expense.
    Does this sound like something I can do myself? I have taken the battery apart several times now. haha
  5. Patrick Wong
    18,200
    6,490
    Since you were unsuccessful in identifying broken sense wires, then it would make sense that you might fix DTC P3030 by replacing the module busbars that are encased in orange plastic. That would give you new sense wires that plug into the battery ECU.
    I'm sure that you could do that job yourself, if you could order the busbars from the parts dept.
  6. jk450
    jk450 New Member
    Yes, it's plausible; that's why it was mentioned a week ago in this thread, along with the observation that the new battery - and its installation - may still be under warranty. If you're looking to save money, you may want to pursue that issue.
  7. bwilson4web
    15,934
    No problem, you were provoked! I had pointed some others towards you if it were real.
    I've seen two postings where the connector where the sense wires plugged-in had corrosion damaged pins. Pull the plug and/or test continuity through the connector as this might be a low-cost, alternative. (Take photos if you do, please.) I believe in one case, they didn't repair the plug as much as jumpered around the plug (cheap!)
  8. colonel570
    48
    Elon, NC
    2001 Prius
    This is the old buss bar off the old battery. Looks crappy to me. One of the wires fell out of the clip that goes into the battery ECU because of corrosion. yuck no wonder it didnt work.
  9. colonel570
    48
    Elon, NC
    2001 Prius
    Another dealer replaced the battery under warranty.
    Same problem as before. I think they are stumped too!
    Ideas?
  10. bwilson4web
    15,934
    Since your last posting the traction battery was replaced?
    Did they measure the 19 module voltages?
    Did they offer any codes?
    Thanks,
  11. bobofky
    bobofky Member
    107
    My local dealer (Lexington, KY) scanned my 2001 Prius about a month ago for $67+. Dealer at Knoxville, TN charges $80.00. Your dealer is too high and making money off you. Your problems have more to do with age of the car than the miles. My 2001 Prius original battery died in January 2009 at 192,000 miles. My sister-in-law's 2001 Prius original battery died in September 2009 at 127,000 miles. The Toyota replacement battery died after 18 months and 26,000 miles. I think that the replacement batteries from Toyota have been setting in a warehouse for a number of years and therefore won't last long. It took 22 days to get my battery after the order was placed. I suspect it came from a warehouse in Japan where it had been stored since being manufactured in 2001 or so. I am trying to find out if there is a way to tell when a battery was manufactured.
    All of your codes are battery related. Call David Taylor at 919-774-4037 to get information about his business that refurbishes 2001-2003 Prius batteries with 2008 and 2009 cells at a much lower price than the unreliable Toyota batteries.
    Earlier I stated the the replacement battery had died. The local dealer's diagnosis was that the car needed a new hybrid battery. At the time I was very busy at work and the car did not exhibit the behavior that I observed with a failing battery. I let the car set for a number of months in the back yard because I didn't have time to bother with it. I did start it up occasionally to keep the 12v battery from discharging. The second time that I tried to start the car, the 12v battery was completely dead. I put a battery charger on it and left it there until I was able to give the car some attention, about six weeks. My work schedule returned to normal so I decided to investigate the status of the Prius. I unhooked the battery charger and started the car. The screen of death (Red triangle, Main, and Car with an X) was still on. You can get back to normal displays by pushing the display button. The Red Triangle remains on the Instrument panel and the "Check Engine" light is on. The Energy display showed the hybrid battery charge at two bars. I let the engine run and in about 5 minutes the battery indicator went up to 3 bars. Another few minutes it went to full 4 bars. I have rarely seen that. I decided to drive the car around the block and it performed perfectly. The I drove about 10 miles on I-75. The car ran beautifully. The next day my wife wanted to go to another city about 30 miles away. I drove her there. The Comsumption display went up to 46.5 mpg. The next day we made about a 200 mile trip and the mpg went to 47.9. The car ran the best that it ever had. It was time for gas so I filled up and the calculated mpg was very close to the displayed. The next day we repeated the 200 mile trip. When I started the car, the screen of death did not show but the "Check Engine" light remained on. When we returned home the mpg showed 49.7. The next week I drove the car to work and around town. I went to my mechanic and he turned off the "Check Engine" light and cleared all of the code\s. It has been almost a month since I started driving the car. The performance is better than it was when I bought the car and the mpg stays in the high 40s. My theory is that the 12v battery had a glictch and was not delivering the current required by the computer which caused the behavior problems and the error codes. By discharging the 12v and recharging it the glitch went away and the computer is operating normanlly. No error lights have appeared. Needless to say, I am very happy and pleased to know that my replacement battery is doing its job. The Prius is a "wonder" car. I don't know why everyone doesn't want one.
