Dealer told me my 2004 Prius engine is toast, are they lying?
Discussion in 'Gen 2 Prius Main Forum' started by Martha White, Nov 24, 2024.
  1. Martha White
    Martha White New Member
    I have a 2004 Toyota Prius with 181,000 miles. I have owned it since 2010. Big battery already replaced in 2017, always kept the oil changed. "Cylinder 1 misfire" code started showing up intermittently 3 years ago, now has advanced to "various misfire" codes. The engine does seem to be missing more frequently in the last 6 months. It has never used oil. I had the coils and spark plugs replaced February 2023. Cylinder misfire codes started up again right away. Took it to the dealer October 2, 2024, they said the engine needs to be replaced, spark plugs are oil/carbon fouled. They suggested I buy a new car, surprise! I checked the oil after 6 weeks, oil level was fine.
    1. Does anyone know how I find out what's really wrong with my Prius? I live near Knoxville, TN.
    2. Does anyone have any thoughts on buying a new Prius in 2025 in the United States? I wanted to wait until I had 200,000 on my car, then get an electric car. That no longer seems like a valid option to me.
    If anyone can help a scared old woman out, I would appreciate it. Thanks!
  2. Tombukt2
    Tombukt2 Senior Member
    11,557
    2,030
    Durham NC
    First of all don't be scared I wouldn't be too worried about what they're saying just yet are you against getting a capable code scanner and keeping track of what's going on Do you drive the car relatively often at the mileage your car has you're just broken in good generally engine failures in this model is not a thing most people in that area owning a Prius wouldn't have abused it My parents are from Knoxville area and I just can't imagine I think if you can manage to plug in a code reader and keep an eye on what's going on and drive the car and let's see what we got I wouldn't think your engine is toast No you're driving aren't you? This thing seem loud when the ice engine is running like in the morning pulling out of the driveway or however that goes? You can send me any pictures you like and all of that of your dashboard on and ready and things like that to my name [email protected] I'd love to see what you have going on
    50,804
    who did the plugs and coils? what was their opinion of the misfire after the work was done?
    we can't tell if the dealer is lying without seeing the codes and the plugs condition.
    there are a lot of counterfeit parts on the market, perhaps the new plugs are a problem.
    what is stopping you from buying a bev, while the federal $7,500. tax credit is still in play?
  4. Tombukt2
    11,557
    2,030
    Durham NC
    The owner of my $700 loaded generation 2 '07 the lady that own that car was told it needed $8,000 worth of work so she parked it in front of the apartment and was moving and was going to leave it I came along and paid the apartment maintenance guy who she left the title with $700 put a 12 volt in it and drove it home It's one of the nicer ones we have leather interior not as trace of anything inside very clean there's always something wrong with something when you go somewhere with your car that's their business. Generally you will know your car better than anybody else You're the one sitting in it and driving it all the time even though you may not know it.
  5. PriusCamper
    PriusCamper Senior Member
    11,851
    4,803
    Pacific Northwest, USA
    We call them Toyota Stealerships because of behavior like this...
    It makes no sense that you aren't losing oil but they say the engine is bad.
    Do you have a friend or family member who has experience working on cars? If so we can help walk them through any diagnosis or repair.
    If I were you I'd buy the lowest price ignition coils and spark plugs and swap 'em out, as well as replace the engine air filter and clean the throttle body and Mass Air Flow sensor. Then if that doesn't eliminate the misfire error codes I'd do a compression test and if there was a need for engine work I'd just swap out the engine with a used one.
    All of the above can get very expensive if you don't have a friend or family member to help because there's so many mechanics who charge a fortune and aren't honest. But ask around I bet you can find one.
  6. bisco
    50,804
    she seems to know that it has multiple misfires
  7. pasadena_commut
    pasadena_commut Senior Member
    2,109
    622
    Southern California
    The OP needs to find out where the oil is coming from. The only 3 common sources I can think of are from the PCV valve, past the engine valve seals, and past the piston rings. Any good mechanic should be able to figure out which it is. Only the last one might require an engine swap. At least on most cars the valve seals can be replaced without having to pull the head, although it takes some trickery and slight of hand.
    If it is the rings, well, there are additives that might work but often as not, not. The new Valvoline Restore and Protect might help, but somewhere or other they say after 4 oil changes, so that's something like 20000 miles of driving. I'm also not convinced as of yet that the conditions inside the Prius engine, which is off as often as it is on, are ideal for that product. If it came down to a choice between driving coast to coast 7 times with VR&P or swapping the engine, I think I would choose the latter. Although if the OP already drives a lot of miles it might be worth a shot.
  8. highmilesgarage
    highmilesgarage Active Member
    408
    145
    Kansas City
    the guys at the stealerships are "parts changer" nowadays lacking the diagnostic skills. They don't want to spend time doing diagnostics because they lack the skill, just plain lazy and want the easy job (because of book rate, charge a 2hr job that can be done in 30 minutes) This is what I experienced with stealerships personally and not just something I heard.. I have a friend who has a very high mileage Honda Pilot and they diagnosed it needing an engine because of misfires. When I checked it out, it has 3 bad coils and one of the spark plugs can't be removed because it was galled (previous mechanic messed it up) We replaced all coils and 5 out of 6 plugs and the engine runs smoothly after that. I have lots of other repair recommendation from. the stealerships that were outrageous and a rip off to customers but I have to mention only this one just to make a point...
  9. BiomedO1
    BiomedO1 Senior Member
    2,577
    1,386
    SacTown, Ca
    They're usually not lying outright. Just lazy and don't want to take a chance your high mileage car doesn't break something else, after the repair and get blamed for shoty workmanship. @highmilesgarage stated; they are mostly parts changers. Most talented mechanics leave and setup their own shops and advertise their OEM training credentials.
    1. I'm sure there's at least a few qualified Prius mechanics - Knoxville is a large city.
    2. IMHO, New car prices are a bit steep now, do a price comparison with a slightly used <5 years, well maintained, no accident car. Unless Toyota starts giving away major incentives on new - I personally wouldn't pull the trigger. Check the website below for alternatives - Their 3-day rent to buy program allows you to see if an EV will fit your life style.
    Used Cars for Sale - Hertz Certified | Hertz Car Sales
    Hope this helps......
    #9 BiomedO1, Nov 25, 2024
