Dealer's New Toyota Event - Full of Misinformation
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by LeadingEdgeBoomer, Dec 4, 2009.
  1. LeadingEdgeBoomer
    289
    29
    New Mexico
    Tonight my local dealer had an event for new Toyota owners - NOT just Prius owners. Almost a complete waste of time. I was a few minutes late for the 6PM start, and they hustled us out in an hour instead of the scheduled 90 minutes. Many seniors (older than me, even) who mostly asked naive questions - seem like sheeple who will do whatever the dealer tells them to do.
    I had 3 questions:
    * Oil used in their changes, and price, pretty-much answered.
    * Odd single beep about 15 seconds after Ready - no time to ask.
    * Inferior FM reception - ditto.
    Like an earlier thread (last posting was 11/15) there was misinformation at the most basic level:
    * Re the go pedal recall, SAID IT INCLUDED THE 2010 PRIUS. They got the CA tragedy right, Lexus with wrong and unfastened floor mat. They also said some recalled cars will get a switch that drastically drops the engine power if simultaneous ineffective braking and high engine RPM are detected - FIRST I'VE HEARD OF IT.
    * Re shutting engine off, they insisted that the car could not be shut off with the Power button if the car is going at any but the slowest speed, since the tranny always moves to Park. Seems I have read that a 3-sec button hold will kill the engine, but I had not enough info to contest the statement.
    * Re OCI, they said the manual requires 5K miles OR 5 MONTHS. Said if your driving is short trips in town, THEY RECOMMEND 3K MILES OR 3 MONTHS.
    * Re oil to use in the new Prius, said they use whatever the car's manual recommends, 0W20 synthetic for the '10 Prius. One Prius owner said he does is own OCs, has always used Castrol, and cannot get the required oil. Asked why Toyota charges $11/qt for their oil, service mgr could not answer. I piped up that Mobil 1 is widely available, and since I was anonymous it did not consign me to Toyota Service Hell.
    Service mgr did note that, "for the time being," OCs will cost $37.95 for all 4-cyl and 6-cyl Toyotas, including 0W20 synthetic for new Priora (see Wikipedia entry for Prius, under Name for the actual plural of Prius). How that fits into the 5K service was obfuscated, but if that's the cost it is a good deal.
    I talked to the DIY OC guy afterwards. Turns out he is much my senior, had just got his first computer(!), and was completely unaware of priuschat.com - which I recommended highly. I explained that, because of PC, my knowledge greatly exceeded the salesman's. He had not yet done an OC yet, and he did not know of the panel to drop to access the drain and filter. Told him maintenance instructions, with pictures, are available at PC.
    I also mentioned the experience of others here of long storage depleting the 12V battery if the SKS is not turned off. Surprised him, made me repeat it to his wife - they are about to go on a long vacation. I forgot to mention that the car is supposed to stop looking for a fob after a few days.
    I am thinking of suggesting to the dealer that they have a Prius event with enough time to drill down on real issues. I doubt that they will, since they were ill-informed (or worse) and admitted to "learning along with the rest of you," in spite of having taken a Prius "class."
    All in all, a disappointing experience. I'm out of there for 5K maintenance, and all maintenance after the 36K mile warranty. In Santa Fe we have Toyotech, which people at cartalk.com recommend highly. Plus they are near The Chocolate Maven, a sinful place for breakfast or lunch.
  2. dogfriend
    7,512
    1,188
    Carmichael, CA
    You can easily demonstrate this for yourself with your 2010 Prius. I doubt that it is different from the Gen2 Prius.
    Here is a video of Gen2 shutoff at 70+ mph.
    4 people like this.
  3. ALS
    ALS Active Member
    590
    294
    Pittsburgh
    The one I went to in Pittsburgh was just the same, boring to say the least. The senior, I'm only here for the free food and gifts made up 75% of the people that showed up.
    The service manager was pushing the 4K mile oil changes instead of 5K miles OCI.
    Pretty much they were pounding home the fact that people should get their car serviced and buy all their parts at that dealership. :rolleyes:
    They were nice and very knowledgeable but it could have been done so much better. I guess being a car guy I expected more info and had it laid out better with more detail and explanation.
  4. going red baby!
    going red baby! still a n00b
    610
    96
    Los Angeles
    LOL. She didn't seem to have this demonstration planned out too well. I was a little worried about the outcome, especially when she wasn't sure if she still had working brakes or not.
    If you need to do this, do you still have power steering? And the brakes work the same or not so much?
  5. dogfriend
    7,512
    1,188
    Carmichael, CA
    I have done it a few times at lower speeds (< 30 mph). The brakes work normally, the steering effort seems to go up slightly, but is still fine. The car has to come to a complete stop before you can shift to P or restart the system.
  6. cpatch
    cpatch New Member
    383
    81
    Carlsbad, CA
    If you have bluetooth, that beep indicates that the system has connected to your phone.
  7. Tideland Prius
    16,406
    power steering doesn't work (but then again, you're just making small changes to pull over to the side of the road. Hopefully you're not facing a corner)
    power brakes don't work BUT like all cars, there is a.. umm. vacuum I suppose it's called. The idea is to slowly brake like you normally would. If you pump the brakes, you'll use up the vacuum and then you're gonna be SOL cause you'll be using two feet to press the brake pedal and get it to slow down.
    Hopefully someone more technical can reword what I said above with the proper terms. Try it on a regular car. Get into the car and press the brake. You'll hear a whoosh sound and you can press the brake all the way to the floor. Pump it a few times and you'll notice that the brake pedal becomes hard and impossible to push. Just turn the car on and it'll go back to normal.
    That is true. They will install a device in some cars that will kill the power if both the brakes and accelerator are pressed at the same time (wonder how that'll affect launches for drag racers LOL).
    Also, shorter OCI are recommended if you do short trips only or drive on dusty roads often. Then again, the manual is vague.
  8. fuzzy1
    10,332
    They don't?
    I thought this 2010 Prius was my first car with a power brake boost that still works even when the ignition is OFF. I hear it fire up the moment I open the door, well before the ignition is turned on. Pumping the pedal 20 times, while still OFF, doesn't change the pedal feel, but the power booster does keep running to recharge itself.
  9. Tideland Prius
    16,406
    haven't tried on the '10 but the '05 works the same as our '02 Camry.
