decisions on new tires
Discussion in 'Gen 3 Prius Technical Discussion' started by liteguy, Feb 9, 2011.
  1. liteguy
    liteguy New Member
    27
    oregon
    Ok, here's my funny but frustrating story. Last Novemebr I installed a new set of Michelin X-ice snow tires for the winter. Which by the way are excellent winter driving tires. So the dealer that sold me the tires told me they would stash my OEM tires for a few days untill I could send someone over to pick them up and store them in my warehouse. When I went back one of the shop guys had sold the tires. Woops. The OEM tires had 8000 miles on them and I really like the ride. I think they were the yokohma's. So the dealer made me a deal. Basically I bought one tire and he gave me three tires. And I installed the Nokian entyre which is their top of the line fuel saver tire. Here is the problem though, they are noisy. And they ride a little rough, but I could live with that because they do handle well. But the noise is not acceptable. I'm going to take them back and get a new set of Michelins. I'm looking at two models. The new energy saver tire and the Harmony. I talked to the Michelin rep on the phone and he said that both are good but the harmonys will out last the ES tires with only a slight decrease in milage. Does anyone out there have any experience with either tire.
    AJ
  2. Teakwood
    Teakwood Member
    491
    73
    New Mexico
    What tire pressure are you using?
  3. liteguy
    liteguy New Member
    27
    oregon
    I'm running 38 in the front and 36 in the rear.
    50,803
    i would get the energy savers. quiet, smooth and sweet mpg's. worth getting less longevity in my opinion. who wants 80,000 miles of misery?
  5. liteguy
    liteguy New Member
    27
    oregon
    That's the tires I ordered in. Don't get me wrong, the Nokians seem to be a solid tire. Great handling and very quiet at lower speeds but gets noisy at speed. I've been a Michelin man for ever and I thought I would just try the nokian.
    I will post back when the new tires go on.
    AJ
  6. Mendel Leisk
    40,234
    Bridgestone Ecopia EP20 are one OEM tire Toyota's been using on the 2010's. I believe they only come in 195/64R15. We put a set on an '06 Civic Hybrid recently. I found the feel good, they are LRR, and not too pricey. Likely too late, but anyway.
    Also, we had Nokian WRG2's on that vehicle, on separate steel rims. They're good for snow, virtually a necessity once the the OEM all-seasons (Bridgestone Insignia EP200_02, identical tread pattern as EP20) were about half-way worn. The only thing with the Nokians: they may claim to be LRR, but in our experience they imposed about 15% mileage penalty, comparing to the OEM or EP20.
  7. don_chuwish
    don_chuwish Well Seasoned Member
    816
    182
    Southern Oregon
    I'm disappointed to hear about the Nokian enTyre being noisy. In my ongoing search for less road noise I'd hoped that might be a candidate (along with the LRR benefits). The search goes on.
    - D
  8. jdenenberg
    jdenenberg EE Professor
    3,910
    1,908
    Trumbull, CT
    2020 Prius
    LE AWD-e
    Careful, you can't directly compare MPGs between two different tire sizes without correcting for the difference in revolutions/mile. My detailed records on Nokian WRg2 tires say that they are LRR and actually get better MPGs (by more than 2% - see the attached spreadsheet for details) than the OE tires (GY Integrity in my case).
    JeffD
  9. bisco
    50,803
    my daughters nokians were a nightmare. but i have never seen anyone else here with a complaint.
  10. liteguy
    liteguy New Member
    27
    oregon
    The Michelins went on today and they are very quiet and much smoother running. I will post back after a few tanks of fuel.
    AJ
  11. yukon2PRIUS
    yukon2PRIUS New Member
    Regina
    Which ones did you end up going with? Harmony or energy saver? I might be needing some new tires soon.
    Thanks
  12. Den49
    Den49 Member
    498
    269
    Maryland
    I replaced the OEM Yokohamas with Michelin Harmonys about 3,000 miles ago. I have noticed no decease in MPG. The Harmonys are much better in every aspect: ride, handling, traction, etc., and they will last a long, long time. I have had a lot of cars with Michelin tires and other brands. Some of the Michelin's best and often unappreciated attributes are that they hold their balance, structural integrity and wear evenly, unlike other cheaper brands which get flat spots, worn edges, slipped belts, etc. and have to be replaced prematurely. When selecting tires, MPG is much less important than traction, comfort and longevity. You can lose all and more than the initial and MPG cost savings you might get with a LRR tire by having to replace them more often than a higher quality, longer life tire, such as the Harmony.
    As always, others will disagree, however LRR tires overemphasize small laboratory calculated MPG savings as green marketing gimmickry, but have a higher overall cost due to more frequent LRR replacements when all tire-related costs (purchase, mounting, balance, alignment, MPG) are considered over the life of a car. LRR=PWPF.
  13. Mendel Leisk
    40,234
    All the tires I'm comparing are the same size, ie: same outside diameter. To be fair, our previous Honda Civic Hybrid seemed very sensitive to rolling resistance.
    The impression I got with the Nokian WRG2 was that their mileage penalty was least on the highway, and most in stop-and-go. In other words, they were more reluctant to get rolling, but not so bad once underway.
  14. jayrider
    jayrider Member
    163
    17
    southwest illinois
    I've only got 8k miles on my Prius so it will be a while before tires are needed. If gas is $6 a gallon in a few years, the eco tires may make sense. Right now a set of Falkens is about $120 less a set than the Conti eco's. Not sure how long it would take to recoup the extra cost. Of course, how long they hold their tread would also need to be factored. In my case, like Den49, I'd be more concerned with ride,traction and noise than saving money on brand,type or cost than mpg.
  15. adamace1
    adamace1 Senior Member
    1,403
    193
    Charlotte, NC
    i think LRR tires make up a chunk of thier cost with gas savings. My stock tires have half tread left at 34,000 miles, so i will get another year out of them. I should have 55,000 on them next year when i need inspections again. I don't want to loose mpg, and i have no problem with getting over 50k out of my tires.
  16. F8L
    19,011
    4,082
    50
    Grass Valley, CA.
    Have you calculated the potential total cost difference between the Harmony and the Ecopia Ep100? The Ecopia is $32 cheaper per tire not accounting for the periodic $70 rebate that can be applied to Bridgestone and Michelin. The Ecopia should have a 3-4mpg edge on the Harmony but should wear out sooner. It would be a fun exercise. :)
  17. F8L
    19,011
    4,082
    50
    Grass Valley, CA.
    I just performed a quick calculation and the EP100 at $73 each and the Harmony at $106 each, the Ep100 came out ahead by $62 assuming the ep100 gets 3mpg more over 80,000 miles but having to replace the ep100 twice. This accounted for a $60 mount and balance and using the $70 rebate.
  18. adamace1
    1,403
    193
    Charlotte, NC
    also add the over 100 gallons of gas saved and not burned :)
  19. F8L
    19,011
    4,082
    50
    Grass Valley, CA.
    Agreed but let's stay honest and deduct a bit for tire manufacturing. :)
    The Harmony's have an extraordinary longevity. Do this same exercise for a tire with a rating of 400-480 vs. the Ecopia and the savings really add up. I realize those ratings don't really mean much but it all we have to go off of besides tire life warranties. :)
  20. Mendel Leisk
    40,234
    We used Michelin Harmony twice on a '91 Accord. The first set was down to the wear bars within 60,000 kilometers, precisely half the treadware warranty. Our second set we got halfprice, because of this. This car passed from our hands before that second set got much wear. At least the warrantied mileage is good.
