Deep cleaning Gen 2 air ducts
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Chris77*, Jul 22, 2022.
  1. Chris77*
    Chris77* Junior Member
    57
    16
    Hi. I see a number of posts about cleaning the HVAC system in gen 2 Prius and I don't like them (spray can projects). I would like to take the system apart and clean each piece. I have been suffering from sinus mold allergies. I just duct cleaned my apartment HVAC and that worked out great, the cleanest air I have breathed in awhile. I don't think there are any short cuts here. How do I take everything apart safely what needs to be done to the evaporator and blower? I found one diagram that just has evaporator and blower without the ducts and vents. Does anyone have a complete diagram? I am trying to do some thinking here before I start taking the dash apart. I have to watch out for the air bag? What concerns and pointers do you guys have on the project? Also, I think I should clean the hybrid battery fan and duct while I am at it. Anything else? Thanks for your time anyone who participates in the thread.
  2. mr_guy_mann
    mr_guy_mann Senior Member
    4,050
    1,976
    NJ-USA
    Look up the A/C evaporator replacement procedure in the service manual. You have to remove the entire dashboard. That will let you remove the air ducts. To get inside the HVAC case and clean the evaporator and heater cores, you need to recover the refrigerant charge, drain the cooling system, remove and disassemble the case.
    When you're done, put it all back together (might as well install a new evaporator core at that point), evacuate the A/C system. Then add the correct weight of 134a refrigerant and some of the correct oil.
    Probably something around 10 hours of labor for the core. Cleaning things takes longer. Screenshot_20220724-162131.jpeg
    This is a Gen2 I did the core on a while back. It would have been some easier if I had lowered or removed the steering column.
  3. jdenenberg
    jdenenberg EE Professor
    3,943
    1,940
    Trumbull, CT
    2020 Prius
    LE AWD-e
    I avoid mold in the AC evaporator coil by always turning off the AC compressor a couple of minutes before arrival. This dries off the coil and prevents the development of mold.
    JeffD
  4. pasadena_commut
    pasadena_commut Senior Member
    2,662
    791
    Southern California
    Maybe flush the drain line from the evaporator, which runs under the front passenger side carpet. Apparently it can get stuff stuck in it and that would tend to promote mold growth.
  5. Chris77*
    57
    16
    My research came out the same. I found a detail guy from the business that cleaned my HVAC ducts in apartment. They are going to use a combination of blower, vacuum and disinfectant. Not only can we not clean the HVAC in the prius without taking it apart and discharging the system but it can't even be inspected. There is a guy on youtube experimenting with drilling a hole in the plastic housing so he can get a scope in there to look around. Then he claims he could patch the plastic once done. I never like the spary can methods but looks like the best we have got. My problem isn't smell but a lot of dust. I am hopeful the detail job will do the trick. Ideally would like to have a look at the coils. If I continue to have health problems due to this dust in the Prius I will take the whole thing out and clean it, but not until the weather cools off.
  6. Mendel Leisk
    41,528
    ^This. And more like "a couple of miles", minimum. Ensure the fan is running on moderate/high speed too.
    Too, reduce your use of AC: on temperate days, and/or short trips where AC will barely have time to stablize. Roll down the windows, lol.
    The mold issue pretty much never happened prior to the adoption of automotive AC.
  7. Yanadelancy
    Yanadelancy New Member
    2012 Prius Alpha
    Found this thread while searching. Just want to say that I found the YouTube video where somebody points out the best spot to drill a hole to get into the evaporator with a probe. I did get in there with my probe (drill a hole just below and this side of the lobe that sticks out under the foot well driver side of the plastic casing) and saw that it looked kind of nasty, but even after I steamed and sprayed the hell out of it in there, I get a cigarette smell from the heater enough to give me an asthma attack .
  8. Yanadelancy
    2012 Prius Alpha
    I’m probably going to get rid of the Prius rather than disassemble the dash. But I might take a picture of the hole drilled and what it looks like inside for the benefit of everybody else.
    I suspect I was not able to get to the nastiness that must be caked on the heater core and hvac ducting
  9. pasadena_commut
    2,662
    791
    Southern California
    Toyota sells a foaming cleaner for the evaporator. It goes up the condensate drain hose as foam, does its scrubbing bubbles thing, then all the bubbles burst and it runs back out through the same hose. I don't recall other details, but it is what the manufacturer recommends for cleaning that part.
    As far as cleaning the ducts, well, if somebody smoked in it it will take a long time to get rid of the smell, since the tars and such stick to the plastic walls and take a very long time to evaporate off. It could be that a substantial fraction of the cigarette smell when the heater is on is actually coming from surfaces which are not in the dash. My son briefly had a Tacoma that had been smoked in, and most of the smell came off by in about two months by repeatedly cleaning all the exposed surfaces and letting the truck bake in the hot LA sun. He never did anything to the vents.
