Diagnostic codes: Is my hybrid battery failing?
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Katrina O, Jul 15, 2017.
  1. Katrina O
    Katrina O Junior Member
    66
    Seattle, WA
    So over the past couple of weeks my check engine light has gone on & off a few times. The first time it was on for a few days; subsequent times usually just a few hours.
    Took it to a shop (not hybrid specialists & I've only been there a few times but they have good reputation) they ran the codes and got : P1121 Coolant Flow Control Valve Position Sensor Circuit Stack. C2318 Low Voltage Error (Power Supply Malfunction), P0A0F Engine Failed To Start, B2799 Engine Immobilizer System.
    The shop replaced the water pump (they saw that it was seeping, and there was low coolant in the reservoir). The light came back on 2 days later, I talked to the shop and they said likely the hybrid battery starting to fail.
    Thought I'd run this buy you knowledgeable folks before starting to get super worked up (I am thinking of taking it to one of the few local hybrid specialty places - I prefer independent shops - to get the battery tested but perhaps someone has a better idea for how I can do some DIY testing without going to a shop? TIA!
  2. windstrings
    windstrings Certified Prius Breeder
    6,280
    378
    Central Texas
    I guess technically all batteries are starting to fail LOL!
    Need to know on what basis they say that, do you have any symptoms to report about how the car behaves or how fast it charges are discharges under a load when driving?
  3. Katrina O
    66
    Seattle, WA
    no it was just their guess I think based on the age/mileage and the fact that check engine light is going on/off intermittently and fairly frequently (every couple of days). I did a little research and discovered that the low voltage code corresponds to the 12V and not the hybrid battery. Having a harder time determining specifics on the other codes.
    50,826
    sounds like they're clueless, i wouldn't go back. we don't even know if those codes are valid. get it to a shop with toyota diagnostic software. then the toyota troubleshooting tree will narrow down the search.
    check engine light can be a lot of things, but not the hybrid battery.
    how many miles on her?
  5. Katrina O
    66
    Seattle, WA
    thanks, I'm beginning to think the same. There are a few shops around here that have hybrid certified mechanics, would they have the right equipment to diagnose? My experiences with going to car dealerships for work here in Seattle haven't been great so I tend to avoid. She has just under 102K miles.
    Very good to hear that check engine light is NOT indication of hybrid battery trouble. I've seen a number of posts on this forum about expected lifespan of180K (and the battery lasting that) which would be nice :)
    #5 Katrina O, Jul 15, 2017
  6. bisco
    50,826
    it's not likely the battery at that mileage, especially in your climate. a good hybrid shoppe should have the correct software, be able to properly diagnose the problem, and fix it correctly without guessing.
    a check engine light can be as simple as a loose gas cap.
    Katrina O likes this.
  7. Katrina O
    66
    Seattle, WA
    Thanks, good to know. It was originally a California car (Bay Area/Marin) its previous owner drove it up here to Seattle & I bought it just over two years ago.
  8. Travis Decker
    Travis Decker Active Member
    139
    116
    Portland OR
    Incompetent shop. You need a three-way valve. Test 12 v battery replace if needed. Never take your car back to that place
    Nexus 6P ?
  9. Katrina O
    66
    Seattle, WA
    sorry I'm not mechanically knowledgeable. 3-way valve?
  10. Travis Decker
    139
    116
    Portland OR
    G9020-47031
    Nexus 6P ?
  11. Travis Decker
    139
    116
    Portland OR
    G9020-47031 is Toyota part number. Email me [email protected] I can help you find someone to fix the car that's not an idiot
    Nexus 6P ?
    Katrina O and Raytheeagle like this.
  12. Katrina O
    66
    Seattle, WA
    ok looked it up, you mean the coolant valve. The shop did look at this but didn't replace it, here's what the shop wrote:"Had technician turn on vehicle while this tech felt control valve for flow. Coolant feels like it is flowing, but difficult to tell if all 3 passages on valve are working properly. Recommend replacing water pump as starting point. " [note they had determined that water pump was leaking]
    my next stop is one of a couple local places that are hybrid specialists, Greentec Auto or Northwest Automotive (likely the latter, the former would be very inconvenient as far as location)
  13. Travis Decker
    139
    116
    Portland OR
    Where are you? Greentec is not what you want
    Nexus 6P ?
  14. Katrina O
    66
    Seattle, WA
    I'm also about to engage in (what I am sure will be) a fight with the dealer that sold me the car (Ford dealership) since they did front pads/rotors before I bought the car but I've since discovered they were done wrong (at least one place has said the rotors clearly WEREN"T done, plus the brake hardware is missing which it looks like may be causing premature failure of brakes due to uneven wear). And I had been so happy with how low-maintenance this car has been (esp compared to my previous car, a 1999 Passat)
  15. Katrina O
    66
    Seattle, WA
    Seattle. West Seattle specifically, I work at the UW.
  16. Travis Decker
    139
    116
    Portland OR
    Drive to Portland! I'm glad to fix it for you at my shop it's all we do all day long. We had one come in this week from a local dealership that was quoted $4,500 for a new inverter and we fixed the car for 350 bucks. Prius is very reliable car but most people who fix cars don't have any understanding of how it actually works
    Nexus 6P ?
    windstrings likes this.
  17. Katrina O
    66
    Seattle, WA
    LOL I do like a good road trip but don't have the time. Appreciate the offer. My understanding is that same code can be due to a low coolant level (it was low, with nothing in the overflow tank)? Mind you I had all fluid levels checked at my last oil change on June 15th.
    So nobody competent up here (other than dealership)?!
  18. JimN
    JimN Let the games begin!
    7,028
    1,116
    South Jersey
    Owners also need to take some responsibility. Inspect the fluid levels at some regular interval and after service. Did you lose an entire tank of fluid in a month? When they replaced the pump did they fill the tank? Look for white residue or pink fluid in the engine compartment.
  19. Travis Decker
    139
    116
    Portland OR
    Dealerships are not any better. We get misdiagnosed cars from them once a week. I will ask a bunch of other hybrid shop owners who is good in Seattle, but you need to find someone who does lots of Prius.
    Nexus 6P ?
  20. Katrina O
    66
    Seattle, WA
    Ok thanks appreciate any info you come up with. There *have* to be places here, Prius is probably the 2nd most common car (after Subaru).
