I've noticed what I think is strange behavior of my MFD lately. I typically have the display off. Lately, in the morning on my way to work, I've turned it on to check outside temperature. When I turn it on, it's very dim, and slowly comes up to full brightness over 10-15 seconds. It's almost like the backlight (?) is coming up to full brightness slowly. Once it's at full brightness, if I turn the display off and then back on a little later, it snaps on to full brightness as I would have expected it to the first time I turned it on. If I turn it off before it's at full brightness, and then back on a little later, it stills exhibits this kind of brightness rampup thing. Anyone else notice this behavior? Anything I should be concerned about backlight or LCD or the something else in MFD getting ready to die? Mornings have been in the mid-40's (F) lately, do not know if maybe there's a cold(ish) sensitivity... Thanks, Mike
<div class='quotetop'>QUOTE(SebMike @ Apr 20 2007, 04:53 PM) [snapback]426975[/snapback]</div> Hi Mike, The search tool is a wonderful thing. Using it you'll find me asking the same Q beginning last winter. Our Prius is an '04 but the dim MFD didn't occur until what ~ 6 months ago? The guru who responded to me basicly said, fahgedaboudit ~ Meaning the MFD light is akin to a flourescent lamp. Ever have any compact flourescent lamps in your house? You'll notice the same behavior ... namely that it takes a few short moments for the lamp to get up to speed ... especially on cold mornings after being off all night. Hope that makes you feel as good as I did, when I got the good "all is normal" news.
Beauty, thanks hill. That does make me feel better...I thought it looked like a slow flourescent tube coming on too, just without all the flicker you get with the cheap ballasts/fixtures in the garage I even tried the search tool, but couldn't find a symptom that sounded just like mine...in fact some threads I found made me feel more worried than I started. Regardless, thanks for the reply. Mike
<div class='quotetop'>QUOTE(SebMike @ Apr 20 2007, 04:53 PM) [snapback]426975[/snapback]</div> Mine does this too. But so does my laptop. And my desktop with LCD monitor. They are consistent enough about it that I'm not worried.
