Ding on front bumper
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Rory Tate, Jun 1, 2011.
  1. Rory Tate
    Rory Tate New Member
    Canadian
    I ran over a plastic bucket. The bucket pushed a little bump, about. 1/8inch high and about 1 inch in diameter on the center of the bumper. I hate it.
    What's the best solution to removing it? Very grateful for any suggestions.
    Rory Tate
    Canadian, OK.
  2. firepa63
    firepa63 Former Prius Owner
    1,761
    208
    See if you can pull the "ding" out with a suction cup. The bumper cover is just plastic.
  3. phoenixgreg
    phoenixgreg Senior member
    1,157
    291
    66
    Phoenix
    Is the ding on the "lower lip"? I did that too and had to carefully "back tap" it out by first removing the lower black cover plate to get behind it. With careful pressure, I got most of the ding out and then purchased a brush bottle of matching touch-up paint from the dealer ($12). I carefully bushed over the ding and for the most part, I don't see it, but mine is a dark color which makes a difference. If you have a lighter color, it could stand out.
    Someone here posted a bumper fix using a hair dryer too. Good luck
  4. rrolff
    rrolff Prius Surgeon
    1,610
    246
    So Cal
    You can try the suction cup method - but you will need to heat the area first (heat gun) - DO NOT overheat the area - get it warm, then try to pull it out. If that doesn't work, you'll need to pull off the bumper and go at it fro the back...
  5. Rory Tate
    Canadian
    Thank you very much for your responses. However, I left out a very important detail: the plastic bucket went under the bumper and pushed the 'ding' upward, causing a pimple-like effect on the upper surface of the bumper. In some ways this may be easier to fix but I don't know.
    Further suggestions?
  6. itonarely
    itonarely Junior Member
    36
    Miami
    Coincedentally, I just happened to find several videos on youtube yesterday showing several people removing dents from their bumpers. You might want to take a look there to see if you find any situations similar to yours. In the videos I saw, it appeared that applying heat was key to resolving the issue...
  7. usedtoyota
    usedtoyota New Member
    Pakistan
    You better find some mechanic rather than finding solution here. Because this would ease your problem no matters you spend some money on it.
  8. macmaster05
    macmaster05 Senor Member
    4,050
    730
