Dipstick shows no oil, can I top with 10w30 for a short drive to mechanic?
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Natasha77, Jan 5, 2016.
  1. Natasha77
    Natasha77 New Member
    Charlotte, NC
    So I guess I have one of those notorious 2010 Prius that burns oil like mad.
    I checked my oil this morning and although there's some oil in the system (as evidenced by oil along the side of the dipstick), the dipstick itself isn't registering a line of oil - so it's scary low. Dipstick middle is dry to touch, so not a matter of not seeing the oil. Oil check was done on level ground, cold. No oil spots ever in driveway. No visible oil leaks or even wetness anywhere under or on top of the engine.
    I'm up on a mountain, no neighbors. I have access to 10W30 (used for a different car). Can I use it just to get my car to a mechanic? Or will it cause more damage? Maybe that's a stupid question, but I'd rather ask you guys than try to figure it out on my own and even then possibly miss something important. I have been running synthetic via dealer oil changes every 5-10k (now I know better, but up until today I thought that was the responsible thing to do).
    Thoughts? What would you do? Looking for basic info because I know crap about cars.
    Thanks everyone!
    Natasha
  2. tankyuong
    tankyuong Senior Member
    1,555
    661
    Central MO
    That's fine cause some oil is better THAN none
  3. roamerr
    roamerr Member
    135
    43
    Winston-Salem, NC
    No it will not cause damage. Top it up and don't worry about it. A 10w will flow fine. Just fill with correct in future. Not a big deal
    iPhone ?
  4. Drewintoledo
    Drewintoledo Junior Member
    49
    Ohio
    2015 Prius v wagon
    I agree with the above statements. The first number in the oil's designation, in this case "10" is the weight of the oil when cold. So, you're only affected on startup which really won't amount to anything running it into the service center. Don't lose any sleep on it.
  5. Mendel Leisk
    40,234
    How many miles on it? Being up a mountain might be part of the issue, it's tough on cars.
    Also, just to pile on: you're fine to top up with 10W30.
    sprtent likes this.
  6. The Electric Me
    The Electric Me Go Speed Go!
    9,083
    5,800
    Undisclosed Location
    I would top it off, then drive it to the dealership and have the oil changed.
    Simultaneously they could check for a leak.
    While at the dealership buy a few "emergency" quarts of OEM oil.
    If it's near totally empty, that's a lot of oil to lose in 5000-10000 miles. I'd want some investigation as to why this is happening.
  7. GrGramps
    GrGramps Active Member
    294
    176
    Western North Carolina
    Natasha, You mentioned that you are living on a mountain. Can we assume you had your car on a level place when checking the oil level?
  8. The Electric Me
    9,083
    5,800
    I'm going to place my bet on Yes.
  9. Natasha77
    Charlotte, NC
    Phew, thanks you guys! I tried to send the "YOU GUYS ROCK!!" email prior, but it failed to send! I added the available oil, then added the 0w from down the hill, and then got my oil changed at the dealer. (A decision based on necessity at this point, but I checked it before I drove it and it was in between the two dimples - cold check too so I think all is good). Engine sounds fine, no knocking, no ticking. I did have to add 2.5 quarts though. I think I'll be trading her in and then letting someone else get the benefit of the certified warranty :) I will be monitoring my oil usage carefully until then. THANK YOU SOOOO MUCH!
    #9 Natasha77, Jan 5, 2016
  10. bisco
    50,804
    2016 prius! all the best.(y)
  11. Natasha77
    Charlotte, NC
    yeah? 2016? I was thinking 2012 or so with about 60k on it... BUT for the very first time I can see the VERY real advantage of having a brand new car and being there to ensure it was taken care of as it should be.
    orenji and bisco like this.
  12. bisco
    50,804
    2012 was a good year.:cool:
  13. Mendel Leisk
    40,234
    2015's are still available, discounted.
    orenji likes this.
  14. frodoz737
    frodoz737 Top Wrench
    4,463
    2,412
    33
    ...and start checking you dip stick every fill-up...for the rest of your life.
    tpenny67 likes this.
  15. JimN
    JimN Let the games begin!
    7,028
    1,116
    South Jersey
    Reminds me of the Castrol ads.
