Disable auto-dimming mirror
Discussion in 'Gen 2 Prius Technical Discussion' started by dmclennan, Jan 6, 2007.
  1. dmclennan
    dmclennan New Member
    The auto-dimming mirror is on by default. Is there anyway to set the default to off? I'd like it off by default and can turn-on when in heavy traffic. I don't like it on by default (cars are too green!), but do like having the feature.
  2. Tideland Prius
    16,402
    Hmm, not that I know of. If I wanted it off, I'll simply press the button. It's almost routine now.
  3. auricchio
    auricchio Member
    921
    Cambria, CA, USA
    If you find the mirror goes too dark, ensure that its light sensor (on the back) is not blocked. (If you have dark windshield tinting, there may be nothing you can do.)
    I've not found any way to keep the mirror turned off by default.
  4. IsrAmeriPrius
    IsrAmeriPrius Progressive Member
    4,333
    Southern California
    <div class='quotetop'>QUOTE(Don McLennan @ Jan 6 2007, 09:18 AM) [snapback]371764[/snapback]</div>
    It has On and Off switches, the | and the O buttons on the right.
  5. DougSlug
    DougSlug Member
    124
    Trenton, NJ
    <div class='quotetop'>QUOTE(Rick Auricchio @ Jan 6 2007, 12:38 PM) [snapback]371776[/snapback]</div>
    Alternately, here's a stupid idea: you could tap into the power wire going to the mirror and install a small LED pointing into the sensor so that it never thinks it's dark when you're driving. You would have to find a convenient way of turning off the LED when you DO want to use the auto-dimming feature, though.
    I think this is probably not the kind of solution the original poster is looking for.
    - Doug
  6. darelldd
    6,057
    389
    Northern CA
    <div class='quotetop'>QUOTE(IsrAmeriPrius @ Jan 6 2007, 09:39 AM) [snapback]371778[/snapback]</div>
    Yup, there is on/off, but the OP is looking for a default off. When you turn the mirror off, and park the car, the next time you start up, it is on again. Bad design IMO! If it has a switch, why not allow the user to actually control it. The cruise control, on the other hand is the other way around! I think it should stay on, yet it turns itself OFF the next time you start up.
  7. IsrAmeriPrius
    4,333
    Southern California
    <div class='quotetop'>QUOTE(darelldd @ Jan 6 2007, 10:59 AM) [snapback]371803[/snapback]</div>
    I did not know that. Live and learn.
  8. dmclennan
    Thanks to all who have replied - I didn't think there was option to change the default, but wanted to confirm.
  9. harrycw
    harrycw Junior Member
    48
    Staatsburg, NY
    If you don't use the "Homelink" stuff, you could just unplug the connector in back of the mirror. Buth then it would be OFF off. No switching back on quickly in traffic.
  10. Charles Suitt
    Charles Suitt Senior Member
    1,637
    17
    Dallas TX
    <_< If you elect to "unplug" the electrochromatic Homelink mirror, how could you reduce glare from headlights behind you? I note no ordinary "flip lever" on this mirror.
    I like the mirror as it is once I programmed it to my garage door opener - took three tries to get it to work. If you program yours, be sure to follow the manual instructions "to the letter."
  11. rjmiz
    rjmiz New Member
    I just thought of a much better way! How about a tab you just flip...one for daylight, and another for driving at night,
    or when the guys headlights behind you are too bright. Maybe I shouldn't have posted my idea here, and just patented the idea. he heh ehehehe
  12. darelldd
    6,057
    389
    Northern CA
    <div class='quotetop'>QUOTE(Charles Suitt @ Jan 9 2007, 07:50 AM) [snapback]373011[/snapback]</div>
    Some of us have a tinted rear window. It isn't that I don't like the "feature" it is just that I'd like some control over it. Doesn't seem too much to ask that it have an "off" switch that keeps it off until such time that I want it on.
  13. jayman
    jayman Senior Member
    13,439
    641
    Winnipeg Manitoba
    Shouldn't the Toyota tech be able to change the default profile - eg: Off by default - using the THHT??
