Disable Low temperature indicator light
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by RPotter1770, Oct 23, 2005.
  1. RPotter1770
    RPotter1770 New Member
    I was wondering how to disable the low temperature indicator light on the dash board. I was driving home tonight and it came on at 37° F and it stayed on until the temperature was about 40° F outside. All I could think about is this stupid light is going to be on all winter.
    Thanks for any help.
    Robert
  2. Tideland Prius
    16,402
    Nope and yes, it'll be on all winter :p
  3. Frank Hudon
    Frank Hudon Senior Member
    4,147
    after a couple of winters looking at it.......... your get used to it being on to let you know your mileage is dropping along with the temp.
  4. Wayne
    Wayne Active Member
    723
    27
    Fort Wayne, IN
    My impression always has been that the indicator is there to warn you that you are approaching freezing, where skiddish road conditions exist, especially on bridges, which freeze first and thaw last... In other words, to drive carefully.
  5. paprius4030
    paprius4030 My first Prius
    2,077
    296
    York,Pa.
    Wayne, your right, that's why it's there. But it's a rude, in your face, pain in the nice person reminder to those of us that live in the cold country, that winter is approaching and I'd rather be in the Carribean LOL.
  6. tumbleweed
    tumbleweed Senior Member
    4,067
    690
    Eastern Oregon
    At least to me, a warning light that is on all the time ceases to be a warning and becomes just an annoyance. It is only when things first light up and look unusual that we really notice them and they serve as a good indication that something is unusual or unsafe.
  7. DaveinOlyWA
    15,140
    611
    South Puget Sound, WA
    2013 Nissan LEAF
    duct tape properly positioned will do it...
    i live in an area where i do apprciate it sometimes as a few times last winter it came on at unexpected times. now for people who see it come on and stay on, that would suck.
    for me, we hover at the 45º mark and only occasionally go below that.
  8. Brian K
    Brian K New Member
    152
    With the changeable Maine weather I'm sort of glad it's there. We can easily go from 50 degrees to 10 degrees in just a few hours and the road can become hazardous without one realizing it. Sure it's a pain in the @$$ when we have a spell of -10, like who doesn't know it's icy then? It's during those times of fluctuating temps that it really is worth it's weight in gold. One thing I would change is the temperature at which it warns the driver. It's set way too high IMO.
  9. hdrygas
    hdrygas New Member
    3,650
    Olympia Wa
    My previous car had something similar so I have gotten use to it and just ignore it.
  10. MNPrius
    MNPrius New Member
    177
    Minneapolis
    That light (which I haven't seen yet - but soon!) and the reverse beeping (it's a great idea, just too loud, I have sensitive ears) are the two biggest things that are going to take getting used to in my new car!
  11. Wayne
    Wayne Active Member
    723
    27
    Fort Wayne, IN
    You can turn both the reverse beep and the seat belt warning at speed off. See the Knowledge Base for more info.
  12. MNPrius
    MNPrius New Member
    177
    Minneapolis
    Thanks Wayne - I did see that I could remove the beeping - but I'm taking a wait and see approach. Because I do like it -- if it could just be a little bit softer :p
  13. TonyPSchaefer
    14,816
    2,499
    66
    Far-North Chicagoland
    I scoured the 'net and found this page. I'm too jittery to do anything drastic, but if you're interested, you might want to look into it. The end result is that the "Low Temp" light doesn't come on:
    [CLICK]
  14. paprius4030
    2,077
    296
    York,Pa.
    LOL Tony! Took me a minute though
  15. RPotter1770
    Thanks everyone.
    So I guess there is no magical sequence to turn off the low temperature indicator, except for moving to Hawaii.
    I agree the indicator is a good idea, but to have it on all winter may just prompt me to use the duct tape method. Actually black electrical tape might look better.
    Robert
  16. aaf709
    3,862
    2022 Prius Prime
    Living in San Diego, a drop to 50 is considered extreme, but I can see why that would irritate after a while. I was going to suggest the black electrical tape too. It's either that or try to deactivate the sensor or the light by cutting a wire.
  17. Charles Suitt
    Charles Suitt Senior Member
    1,637
    17
    Dallas TX
    Hi RPotter1770
    As for the "Low Temperature" dash light, DaveinOlyWA's suggestion about duct tape is a solution; however, others have suggested using black plastic electrical tape instead of duct tape - goes well with the panel colors. If it "bugs" you that much, just tape over it. The electrical tape would be easily removed later.
  18. Tideland Prius
    16,402
    Maybe we should ask Toyota to let it turn itself off after it reaches -10°C or something like that. i.e. make it so that the warning is applicable for that temperature range where black ice can form.
  19. DaveinOlyWA
    15,140
    611
    2013 Nissan LEAF
    actually the temp sensor is set to come on at "black ice" temps which is about 37º... assuming salt-less roads i guess
  20. Tideland Prius
    16,402
    Yeah, but have it turn off at a lower temp. It works as a warning at 3°C but below -10, we know it's snow and ice and the road's probablly partially or fully snow covered.
