Disappointments in my 2025 Prius Plug-in XSE Premium
Discussion in 'Gen 5 Prius Main Forum' started by IntnsRed, Feb 11, 2026.
  1. IntnsRed
    IntnsRed Junior Member
    16
    Southern (far from Chicago!), IL
    2025 Prius Plug-in
    XSE Premium
    My disappointments in this car are in 2 areas:
    (1) The size. I knew it was smaller, but thought I'd get used to it. Now after months of driving it, getting into the car is still a royal PITA. Shifting my leg under the steering wheel is problematic every time I get in! My 2019 Prius I never had that problem.
    And while it doesn't bother me, my 6'7" son hates riding as a passenger in the Prius -- there's not enough headroom for him where he had no problem in my 2019 Prius.
    (2) The stereo display in the car is utterly useless! If I could pay to replace the stereo I'd happily do it! (Seriously, does anyone know of a replacement?!)
    I refuse to pay for any pay music service/gimmick, have no interest in Apple or Android, I just want to use AM/FM radio stations. But that massive screen is simply a waste! There are no real functional "pre-sets," and let alone "groups of presets" so you can group stations according to cities/locales.
    I hate this radio with a white-hot passion. Even switching between 2 "favorite" stations requires scrolling on the screen because of an insane use of space on the massive screen. The engineer who dreamed up this interface needs to be mercilessly fired.
    The various controls (heat/ac, heated seats, steering wheel, etc.) in the car are very well done, a vast improvement over my previous 2019 Prius Prime Advance's controls. But good grief, Toyota sure bombed with the radio.
    bisco, KCWhitney and Gokhan like this.
  2. VelvetFoot
    VelvetFoot Senior Member
    1,259
    494
    New York State
    2026 Prius
    I use the instrument cluster for radio station selection.
    I created favorites, a mix of FM and XM on the infotainment screen, and then use the steering wheel buttons.
    I use the infotainment screen for CarPlay stuff, like Maps and OBD Fusion.
    I like the cluster, or whatever the real name is.
    If I'm not looking at maps or car parameters like coolant temp, I turn off the infotainment screen.
    edit: and even I, at ~5' 10 1/2" couldn't fit comfortably in the back seat.
  3. hill
    8,940
    Who knew! You can shrink up to 2 in with your 6"-6" at age 20 - then end up 6 ft - 4" 50 years
    later.
    But yeah, the larger range battery in our 2018 Chevy Volt was similarly small & it was tough to get used to going in & out in fact - never did get used to it. So I feel yer pain.
    Oh - & yea, You're not the only one Heating The instrumentation In modern cars. Picked out a particular ¾ ton pickup model in part because it had lots of tactile control knobs - even for the radio. Even has a full size spare tire!
  4. mingc
    mingc Member
    85
    61
    Portland, OR
    2023 Prius
    XLE AWD-e
    You can scroll through your preset favorite radio stations with the arrow switch on the steering wheel. It works much better that way.
    mva and IntnsRed like this.
  5. KCWhitney
    KCWhitney Active Member
    141
    118
    Connecticut
    2025 Prius Plug-in
    the radio app is much worse in the Gen 5. With all that screen space, why can't they show a box reflecting the channel and song and artist data of the playing song
    IntnsRed and bisco like this.
  6. ETC(SS)
    7,379
    They make trucks without a full-sized spare?!?!
    Who knew?
    Yeeeeah.
    That's a thing.
    As it turns out?
    Size really DOES matter especially when getting in and out of the car - and when you're looking at the bottoms of all those car and truck bumpers in front of you in traffic.
    I'm 5'8" on a tall day and I have to admit that I much prefer climbing into a truck to folding myself into a small car.....unless of course it has three pedals, RWD, and the thrust to weight ratio of a stripped down F-22. :sneaky:
    I haven't looked at this in depth mostly because......I don't HAVE to, but if I woke up in your shoes?
    I'd give them back to you - and THEN - I'd look into Crutchfield.
    https://www.crutchfield.com/S-Z6S2dP9wLtd/ymm/2025-Toyota-Prius-Speakers-Stereos.html
    In some cars, replacing the OEM infotainment system is like removing Borg implants, and my presumption is that given Toyota's corporate culture - they're going to be the same but if there's a way to do it then CF will know 'all the things.'
    You may have to find some graduate student to graft it into the car for you - but any big city will have audio shops.
    Don't forget to speak up when you're talking to them.
    That tinnitus is a bear!
    I've been an electronics tech long enough to have, literally, worked on vacuum tubes and I simply WILL NOT buy a vehicle whose HVAC system has to be operated by touch screen.
    I'm a cord cutter, and the ONE monthly subscription that I pay for is for YouTube Premium ($15 USD) so that I can 'load and go.'
    Videos. Music. etc.... and drive with the screen turned off in audio only.
    That way?
    I can just turn the infotainment system OFF in whatever car I happen to be driving.
    Good Luck!
    #6 ETC(SS), Feb 12, 2026
  7. Mendel Leisk
    41,963
    I'm somewhat less enamored than you regarding the current state of cabin heat/vent "controls". Would be very interested if someone produced a car where you could actually make adjustments while driving, without a serious risk of drifting out of your lane.
  8. PickyAudioGuy
    PickyAudioGuy Junior Member
    16
    Chicago
    Lane assist should keep you in your lane. Shouldn't it?
    flim, PrimeDan and Mendel Leisk like this.
  9. PriusCamper
    PriusCamper Senior Member
    13,124
    5,318
    Pacific Northwest, USA
    There should be an auxiliary input so you can plug a separate sound system in and use that for AM and FM... Also stop by a car stereo shop and see what they recommend. I'm sure they have an upgrade, or will soon.
  10. bisco
    52,434
    The only thing worse than hoping to get used to a car is hoping to get used to a spouse
    flim, Tande, PrimeDan and 3 others like this.
  11. hill
    8,940
    ...... maybe by the end of the 4th decade
    PrimeDan likes this.
  12. ETC(SS)
    7,379
  13. PriusCamper
    13,124
    5,318
    Of course a car stays the same over time and you can count on it slowly deteriorating and getting worn out but not changing much. Whereas a spouse will re-invent themselves many times over the course of a long marriage and the new version may not only be hard to get used to, but they also might make you feel like you're the one who is deteriorating and getting worn out over time. As in the latter is alot harder to get used to than the former.
  14. VirginiaLeePrius
    VirginiaLeePrius Junior Member
    44
    Space Coast, FL
    2024 Prius Prime
    SE
    The only problem is the car will nag you about not paying attention! :LOL:
    mva, flim, PrimeDan and 1 other person like this.
  15. Mendel Leisk
    41,963
    The oh-shit handle on passenger side of our ‘10 is getting pretty squeaky…
    PrimeDan, PriusCamper and ETC(SS) like this.
  16. PriusCamper
    13,124
    5,318
    Never heard that name before, but that's an excellent name for that handle!
  17. douglasjre
    douglasjre Senior Member
    2,211
    741
    Null, NL
    Can I buy your disappointing car from you?
    gramps, PrimeDan and PriusCamper like this.
  18. Blackat
    Blackat Active Member
    480
    345
    Colorado
    2023 Prius
    Limited AWD-e
    I have none of those "problems"
    Sounds like a 'you' problem and didn't figure this out before purchase
    gramps likes this.
  19. notspam3
    notspam3 Member
    104
    57
    Toronto
    2024 Prius Prime
    XSE Premium
    I agree that getting in and out of the car is a little more difficult for taller folk. Surprisingly I don't mind the apple car play. I haven't listened to the radio in years so I can't comment on it, I only listen to mp3's stored on my device. For that the UI works fine.
  20. VelvetFoot
    1,259
    494
    New York State
    2026 Prius
    The A pillar blocks vision at stop signs. Have to be careful.
    #20 VelvetFoot, Feb 15, 2026
    notspam3 and PrimeDan like this.
