Display audio to default to map view?
Discussion in 'Prius v Audio and Electronics' started by moinkoink, Aug 26, 2012.
  1. moinkoink
    moinkoink New Member
    Just traded in our 2010 Prius (III with nav) for a Prius v (Five) with display audio. Love it, and glad we made the switch.
    On our old Prius, the display would simply change back to the map view after ~5-10 seconds. The new car does not seem to do this. No luck searching the manuals or the Internet. Is it possible?
    Thanks for your help.
  2. Boston Jim
    Boston Jim Active Member
    202
    148
    I'm not sure if you've already figured it out or if this helps but in my v five (ATP) (so it might be different), it was in the general 'Setup' on the second page, Auto-change display, just click it to select.
    Good luck
  3. moinkoink
    Thanks for the suggestion. The display audio doesn't have the same menus, and I don't see a similar option. Any other thoughts for those of us without the ATP? Maybe I should have just purchased it :)
  4. ProximalSuns
    ProximalSuns Senior Member
    1,877
    PNW
    Mine seems to stay where I last used it. I never changed anything so I'm guessing that is the default. I like it that way. Let's me decide which screen I want displayed.
  5. JimboPalmer
    12,470
    6,875
    Greenwood MS USA
    Your stats do not hint you have a v, do you? Is it in addition to the 2012 liftback?
