But if you read a little further in the manual: "If SAE 0W-20 is not available, SAE 5W-20 may be used. However, it must be replaced with SAE 0W-20 at the next oil change." So given the choice, I would only go with 0W-20.
Yeah, I was going with the second quote. So if you have both available why not go with the 0w20 was my point. Thanks RodjJo.
I have read it, if it were required, that paragraph would not be there. It appears that many dealers dont read the manual.
