Do Snow Tires Need Breaking-In?
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Rokeby, Nov 20, 2010.
  1. Rokeby
    Rokeby Member
    3,033
    708
    75
    Ballamer, Merlin
    I've just had Blizzak 195/55/R16 WS60 snow tires mounted on a
    separate set of Touring wheels. (Will run them without TPMS.)
    I'll have snow tires at all 4 corners when I get the wheels mounted.
    These are the first snow tires I've had in 40+ years of driving...
    Don't know diddley about snow tires. :confused:
    I'm wondering, is there any reason to have the new snow tires mounted
    on the car and running them on bare pavement well before there is any
    snow so they can "break-in?" It's just a thought. Just what "breaking-in
    would mean is beyond me...
    Or is it best to mount the wheels/snow tires just before it snows the
    first time to save the tread?
    In either case, I'l keep them on for the 10-12 weeks of our probable
    snow season.
  2. 13Plug
    13Plug Active Member
    581
    104
    2013 Prius Plug-in
    No, and don't try to "break them in". Snow tires have a special soft compound and it'll wear down faster when you drive on pavement. Once that soft compound is worn down the rubber is not as soft, but I think that's when you're down below 50% treadlife.
    I wait until the first snow and put the tires on in my garage (yes I have them mounted on extra steel wheels). Actually, I put my summer tires back on in February of this year because of a long road trip, and I left them on until just a couple weeks ago.
  3. BAllanJ
    BAllanJ Active Member
    667
    78
    Kingston Ontario
    Mine are on now before the snow. The advantage isn't just the snow, but the cold. It's around freezing here now and the Integreties traction on wet was already bad. I've heard the recommendation to put them on when the temp is likely to mostly stay below 10C. In Quebec I think the requirement is that they're on by 1 Dec.
  4. Tideland Prius
    16,401
    Mine have been on since the beginning of Nov. They'll be on til late March at the earliest (how sad). Squeeze an all-season tyre and a winter tyre at the same temperature. You'll notice a difference in softness. That's what gives winter tyres their advantage in cold temps. You want the tread blocks to be flexible when you brake and not act like they're solid as wood.
  5. jayman
    jayman Senior Member
    13,439
    641
    Winnipeg Manitoba
    My factory studded Nokian winter tires have a claimed "break in" period. There is a cross-hatch wear area around each stud, and you are supposed to drive "gently" until this cross-hatch is gone
    Something to do with the factory studding process, the studs being in correct position, etc
  6. Rokeby
    Rokeby Member
    3,033
    708
    75
    Ballamer, Merlin
    This snow tire business is all new to me.
    I suspect you northerners think I'm rather simple.
    I will admit to enjoying simple pleasures in understanding new stuff.
    In addition to the lateral grooving called for in snow tires in the
    Rubber Manufacturers Asociation specifications
    -- Hey, I didn't chose that name! --
    there are saw toothed razor cuts: /\/\/\/\/\ across the the face of the
    tread blocks perpendicular to the direction of travel.
    I take it that these allow the tread to open slightly under
    aceleration/braking. (Yes, I know, that would be a negative acceleration.)
    Would that be for better traction on ice vs. snow?
    Jayman,
    Thanks for the info, but...
    I'm in Merlin, the northernmost Southern state.
    Others may benefit though.
  7. Hal W
    Hal W New Member
    872
    53
    Grand Forks,B.C. Canada
    Rokeby: Don't mount your Blizzak's until you absolutely have to. They are made of very soft compound and wear fast on dry pavement. I believe they have pieces of walnut shell impeded in the rubber. Keep them at max. cold setting and they may last longer? Very best tire for snow and ice.People in the far north use these almost exclusively. H
  8. Rokeby
    Rokeby Member
    3,033
    708
    75
    Ballamer, Merlin
    Hal W,
    Can you estimate how long these tires might last?
    I expect to put 2500-3000 miles a year, with any luck
    mostly on bare roads. :rolleyes:
    Are you referring to tire pressure?
    Merlin is the just-barely-north. Could I be "over tired?"
  9. Hal W
    Hal W New Member
    872
    53
    Hi Rokeby:
    I have never used them myself I'm only passing on what my friend told me and he swears by them. You should get many years at that mileage?
    Air pressure. I run 40 and 36 aft. I was just thinking that higher air pressure may slow down the wear?
    What State is Merlin in?
    Cheers:
    Hal
  10. Rokeby
    Rokeby Member
    3,033
    708
    75
    Ballamer, Merlin
    Right now, our beloved Merlin is in a state of economic
    downturn. :(
    The state of Merlin lies between Virginya and Pencilvanya.
    It surrounds our nations capital, Warshnin, on three sides.
    Merlin's largest city, Ballamer, is where I live, and was born.
    Ballamer natives speak a form of Merakin English called
    The Merlin Dialect, more properly "Ballamerese."
    :D
    Thank's for asking. :rolleyes:
  11. Hal W
    Hal W New Member
    872
    53
    Thanks Rokeby:
    By the way that friend live's pretty high up on a mountain so his tires are very well tested for about 5 months a year. H
  12. Fred_H
    Fred_H Misoversimplifier
    558
    481
    28
    Germany
    Hi Rokeby, the tread surface of new tires is relatively smooth as a result of the molding process. After a couple hundred miles of normal driving, the tread surface becomes rougher, which improves traction in icy conditions.
    Once, about fifteen years ago, I had a brand new set of Goodyear Vectors mounted just coincidentally at the very same time that freezing rain set in. On the way home, although I had to drive up a hill where other cars were sliding around, I had no problems. Just an anecdote, but goes to show you.
    So the answer to your question is yes and no. Yes, snow tires need breaking in to reach their maximum potential, and no, they don't need breaking in before it snows, because they will also do just fine without.
    I suggest mounting snow tires when it's most convenient for you. As already mentioned by BAllanJ, when the temperatures approach freezing, the softer winter tires also have better grip on bare pavement, because the summer tires get too hard at low temperatures.
    #12 Fred_H, Nov 23, 2010
