Do the Prius prime and Gen 4 prius share suspension?
Discussion in 'Prime Main Forum (2017-2022)' started by h22fastback, Oct 26, 2018.
  1. h22fastback
    h22fastback Junior Member
    Massachusetts
    New to the prius prime world but do these 2 platforms share the same suspension?
  2. Tideland Prius
    16,402
    Physically, yes but the Prime will have a different tuning setup since it's heavier.
    (Also there are different suspension settings depending whether you get the regular non-Touring Prius models with the 15" wheels or the Touring models with the 17" wheels)
  3. h22fastback
    Massachusetts
    Ok, good to know. Im gonna assume that aftermarket sway bars and chassis braces will work on the prime? Thanks for the reply!
  4. Tideland Prius
    16,402
    They're all assumptions. I don't have a definitive answer but using logic, it seems reasonable that they'll work. (But there's always the outside chance that there's a different bolt or bolts)
