Does anyone know if the Gen II 16" Touring wheels fit on the Gen III Prius?
Discussion in 'Gen 3 Prius Accessories and Modifications' started by Jon S, Aug 6, 2009.
  1. Jon S
    Jon S Member
    185
    84
    The Aloha State
    Question says it all... I sometimes see the Touring wheels on sale on eBay...
    ScottHz likes this.
  2. wvgasguy
    wvgasguy New Member
    1,255
    185
    a
    I see no reason they should not fit.
  3. CAR4TWO
    CAR4TWO New Member
    239
    Grants Pass, OR
    I would LOVE to have a set of those wheels. I wonder if dealers are still selling them?
  4. Bambam650
    Bambam650 New Member
    28
    Cincinnati, OH
    I likey too. Very much.
  5. Jon S
    Jon S Member
    185
    84
    The Aloha State
    found out, a bit too small... they are designed for 195-55R16 tires and Tire rack recommends bigger 16" tires... 205-55R16....
  6. ilusnforc
    ilusnforc Member
    404
    San Antonio, TX
    The tires are specific to the wheel, not the car. According to tirerack.com both the 2010 Prius and the 2007 Touring Prius have the same wheel specifications:
    Offset: +38mm
    Backspacing: 5.27"
    Bolt Pattern: 5-100
    Assuming that the information on Tire Rack is correct, yes, the Touring wheels should fit the 3rd gen Prius.
  7. ScottHz
    ScottHz Junior Member
    Kannapolis
    I put the wheels (& tires) from my 2008 Prius Touring on my wife's 2013 Prius Tow (and vice versa). There is a slight height difference, but both cars have more accurate speedometer readings than before (comparing to Waze avg speeds).
    I'm trying to get the Prius Two to ride as smoothly as the Touring - wondering if the struts are better on the Touring?
  8. ChapmanF
    16,949
    The 195 tires might have lower load capacity than the 205s. It could be worth looking up. It also may be possible to mount the slightly wider tires on the Touring wheels.
