Does anyone use OBD Gauge for monitoring RPM and water temperature?
Discussion in 'Gen 5 Prius Accessories and Modifications' started by Axl, Dec 14, 2025 at 2:24 PM.
  1. Axl
    Axl New Member
    AL
    2026 Prius
    I bought one from Amazon, the brand is KUOWEIHUD, but it is not working, it will restart frequently. So, does anyone recommend a OBD Gauge?
  2. ChapmanF
    18,215
    I use a ScanGauge. It works well, and uses very little sleep power when the car is off.
    Water temperature is a number I usually have on the display. RPM isn't. I had it displayed for a while out of curiosity when I first got the ScanGauge, but it's just not that interesting in a Prius; the engine is always being managed by the car, it does what it does, and after that initial curiosity, the urge to hover and second-guess it sort of fades.
    PrimeDan and Axl like this.
  3. VelvetFoot
    VelvetFoot Active Member
    693
    252
    New York State
    2026 Prius
    On my 2026 LE, I use the OBD Fusion or Car Scanner app, both of which display on the infotainment screen via CarPlay.
  4. rjparker
    rjparker Tu Humilde Sirviente
    10,158
    6,316
    Texas Hill Country
    P10 for years monitoring engine temp and aux battery. Has user set alarm limits. IMG_1006.jpeg
    Axl likes this.
  5. ChapmanF
    18,215
    Interesting! Does a 2026 LE have an engine oil temperature sensor, then?
    I wonder why it would be that much cooler than the coolant.
  6. Dany Dan
    Dany Dan Junior Member
    44
    Québec, Canada
    2024 Prius Prime
    SE
    I use a V-gate vLinker FS Bluetooth OBD2 Scanner with the Torque Pro and AATorque app on Android Auto.
    This allows you to display lots of parameters on the central display with Android Auto including, RPM, coolant temp, oil temp, Volts, SOC, speed, LTFT1, AFR, MAF, timing Adv, etc...
    There are hundreds of parameters displayable on up to 10 panels with dial or digital display.
    I wouldn't do without it anymore, since I use it continuously.
    Axl likes this.
  7. VelvetFoot
    693
    252
    New York State
    2026 Prius
    I've been in iPhone world for a relatively short time, but I've got no experience with Android Auto.
    Car Scanner has a profile for Gen5 "Primes" that provides hybrid-type data.
    No dials on CarPlay.
  8. Dany Dan
    44
    Québec, Canada
    2024 Prius Prime
    SE
  9. VelvetFoot
    693
    252
    New York State
    2026 Prius
