DOES ENGINE RUN WHEN AC IS ON??
Discussion in 'Gen 2 Prius Technical Discussion' started by jiw395, Aug 7, 2006.
  1. jiw395
    jiw395 New Member
    119
    NORTH WEST INDIANA
    On the subject of saving fuel, I've read here on the forums where people say not to idle the prius with the air conditioning on. my daughter's 2007 Camary hybrid, the gas engine doesn't run while sitting in the drive way with the 'air' on, it has a electric compressor which doesn't;t require the engine to operate. Now, I say this because I noticed this when see was cooling the car before leaving, BUT it was only for a few minutes. I wonder if after a longer time, if in fact the engine would start, for the sake of not running down the batteries. ANY thoughts or knowledge of exactly what actually goes on??
  2. darelldd
    6,057
    389
    Northern CA
    <div class='quotetop'>QUOTE(Norman H. Renehan @ Aug 6 2006, 10:42 PM) [snapback]298894[/snapback]</div>
    The Prius engine does not need to run for the AC to operate. Both the Prius and Camry engine will eventually have to run to keep the HV battery charged enough to keep running the electric compressor and fans, however. But for short stops, the engine in both cars can stop running while AC continues to do its thing.
  3. jayman
    jayman Senior Member
    13,439
    641
    Winnipeg Manitoba
    With the A/C electric compressor on, the ICE will only start to maintain the NiMH battery pack above 40%. I've been stuck here in traffic on one of our never-ending summer heatwave +35 C days, and the battery charge will eventually go pink. The ICE will then start to maintain slightly above that point.
    I test drove a HyHi early summer and can also confirm the ICE will stay off with A/C on, if the battery SOC is high enough. Can't comment on the HyCam as I haven't driven one yet.
  4. tmgrl3
    tmgrl3 Member
    315
    I had my Power on for quite a while with the A/C running when I first got the car...July 17...to download all the phonebook stuff....mostly in electric...
    t
  5. IFixEm
    IFixEm New Member
    69
    a gallon south of Microsoft
    <div class='quotetop'>QUOTE(jayman @ Aug 7 2006, 05:41 PM) [snapback]299342[/snapback]</div>
    Jayman nailed it...A/C kills fuel economy. Period. There are ways to lessen the impact but there is no free lunch kids. Gen 1 pri runs the ice with a/c on and kills mpg. Gen 2 will not IMMEDIATELY run the ICE but if you sit a while with A/C on the hv batt goes down, this eventually causes the ICE to kick on before it would with A/C off. Extended A/C run at a stop will cause ICE on. Much better than Gen 1 and FF only cars, but not free.
    Defrost on all Yoda's is linked to the A/C even if the a/c mode is off. Anytime defrost is on, a/c is cooking. Defrost not a/c is my regional problem. 100* about 10 days a year. We worry more about wipers.
  6. hobbit
    hobbit Senior Member
    4,089
    468
    Bahstahn
    That's one of the beauties of electric A/C. If the compressor is a
    mechanical parasite off the engine, you wind up burning off way more
    kilowatts of HEAT from fuel just to get a lousy kilowatt or so of
    cooling capacity. With electric, the engine can run intermittently
    and at higher load and better efficiency to replenish the battery.
    Just like it does to push you down the road, in fact...
    _H*
  7. jayman
    13,439
    641
    Winnipeg Manitoba
    <div class='quotetop'>QUOTE(hobbit @ Aug 8 2006, 09:10 PM) [snapback]299950[/snapback]</div>
    H
    Imagine how efficient home central A/C would be if it employed a variable speed compressor motor. The house I used to have in the burbs I had a Bryant Puron two speed, and that alone made a huge difference in my summer cooling cost.
    Compared to similar size homes on my street, try 1/2 the cost to cool! I also made sure the ductwork was sealed with plenty of aluminum foil tape, and also insulated with R-12 mineral wool insulation.
    When I built the new house at my hobby farm around 3 years ago, I put in another Bryant Puron 2-speed air conditioner. The only other person in that area with lower energy bills has a ground source geothermal system, and his bills are only slightly lower.
    If he sealed and insulated his ductwork, he could probably lower his energy consumption a further 10%.
    j
  8. Tideland Prius
    16,402
    Note it's only for the new Prius. The Classic had a belt driven A/C compressor tied to the engine.
  9. Frank Hudon
    Frank Hudon Senior Member
    4,147
    the A/C on the Classic is just like any other car, but when the compressor cycles off the ICE stops and I've had it off more than the 2k4's ICE in hot weather and in traffic and the battery in the pink. The electric compressor runs when ever the A/C system is on, high and low speed as required by the expansion valve in the evaporator and as such draws current from the HV battery all the time. Once the battery is down to pink the ICE starts and runs more than the Classic with the A/C compressor cycling on and off. Once under way and the ICE is running it's the same on both and I think the Classic does it better without the conversion to HV Battery charging better than the 2k4, the ICE in which seems to labour when the battery is low and charging. This is one area where I think the hybrid compressor on the Accord hybrid is a better bet, when the ICE is running it's clutch is engaged and when the ICE is stopped it's electric driven. As the ICE is running or spinning to protect the PSD at hiway speeds have it run the compressor. When ever your accelerating to start off or the first 5 minute cycle to S4 have it power the A/C compressor. Energy conversion from gasoline to electricity is less efficient that just powering the compressor. My 2 cents
  10. ivfarmboy
    ivfarmboy New Member
    107
    I live in a very hot desert, 115 to 120 for a lot of the summer. How long before the car would overheat if you had AC on parked? If I let it run in my driveway to cool down say for a couple minutes, what do you think would happen. Not going to try it but just trying to figure some limits on this thing. Thanks.
  11. richard schumacher
    7,664
    1,042
    United States
    <div class='quotetop'>QUOTE(GreenFarmBoy @ Aug 9 2006, 01:38 AM) [snapback]300074[/snapback]</div>
    The engine will never overheat because most of the time while you're sitting the engine won't be running. The engine runs only when needed to keep the battery charged. The A/C runs as needed to keep the cabin cool. No problem. Of course you'll burn fuel doing this, but it does not damage the car.
    In fact, note that in hot weather you *must* run the A/C to keep the battery cool! The cooling vent for the battery and its associated electronics is inside the cabin, because the battery system must be kept cooler than can be done by outside air. If the battery system gets too hot the battery can't charge or discharge as fast as it should, and fuel economy (and possibly battery life) will be reduced. Rule of thumb: if you are uncomfortably cold or hot, the battery is also.
  12. Frank Hudon
    4,147
    <div class='quotetop'>QUOTE(GreenFarmBoy @ Aug 8 2006, 11:38 PM) [snapback]300074[/snapback]</div>
    if you did this a first start up the ICE will run anyway, and will help charge the HV battery and then shut off and if the ICE gets to warm the cooling fans come on to cool the ICE and take the heat out of the AC system. Nothing to worry about.
  13. fshagan
    fshagan Senior Member
    1,766
    Noneofyourbusiness, CA
    <div class='quotetop'>QUOTE(IFixEm @ Aug 8 2006, 06:51 PM) [snapback]299936[/snapback]</div>
    I routinely spend about 30 minutes parked with the A/C on. I tested the effect of doing so on mileage. The ICE cycles on for about 30 seconds once or twice during that time, and I was unable to tell a difference in my mileage in weeks where I did that five days in a row and weeks where I didn't do that at all. I suspect in my case I'm storing enough electricity in the battery that I'm not using to full advantage.
  14. TJandGENESIS
    TJandGENESIS Are We Having Fun Yet?
    5,299
    47
    ★Lewisville, part of the Metroplex, Dallas, in the
    <div class='quotetop'>QUOTE(jayman @ Aug 7 2006, 08:41 PM) [snapback]299342[/snapback]</div>
    The HyCam and the Prius run the same, as in, the ICE will stay off until it needs to recharge the Battery. In the HyCam, you have longer to go, and if you are running around in stop and go traffic, it will get to green far faster.
  15. nylion
    nylion New Member
    167
    61
    Seattle WA
    I just got my '06 and I had to sit in the driveway for 20 minutes while the XM radio activated. The ICE stayed off the entire time (I was just under where the battery indicator turns green when I started). I am pretty sure that with the electric multi-speed compressor, the entire quibble over lost mileage is pretty moot. Yeah, maybe the ICE runs a bit more to charge for the AC, but really is it enough to care about, at least in the newer cars?
  16. DanMan32
    DanMan32 Senior Member
    3,799
    27
    Tampa Bay, FL
    Although having a belt driven compressor would imrove the energy conversion, the loss is overtaken by the improved efficiency of using a variable speed compressor which you can't achieve with a mechanically coupled compressor. At full speed, there may be no difference, though Toyota claims that the new system is more efficient. But most of the time the compressor is not running full speed.
  17. Frank Hudon
    4,147
    <div class='quotetop'>QUOTE(DanMan32 @ Aug 10 2006, 01:02 PM) [snapback]301034[/snapback]</div>
    it might not be running at full speed but it's still running and drawing current from the HV battery which has to be replaced and the only place it comes from is gasoline.
  18. Drift Motion
    Drift Motion RMS13
    178
    Pasadena/Riverside, CA
    as long as the Hybrid battery is "high" enough or charged up enough, the ICE wont run
  19. buyaninsight
    buyaninsight New Member
    39
    and as a little side note...part of the reason all the hybrid mileage from the Gov is dropping is beecause they are actually gonna use the AC when running the test...like oh 90% of the population, used to run without it which is the real reson for an electric compressor to reduce the drag and squeeze out an extra mpg on the sticker
  20. Frank Hudon
    4,147
    <div class='quotetop'>QUOTE(buyaninsight @ Aug 13 2006, 08:05 PM) [snapback]302815[/snapback]</div>
    all mileage estimates will drop as a result. Every vehicle that has an EPA estimate will drop, can't help but.
