Does Prius refuse to go into N above 42 mph?
Discussion in 'Gen 2 Prius Technical Discussion' started by RhythmDoctor, Mar 9, 2010.
  1. RhythmDoctor
    RhythmDoctor Member
    135
    Swarthmore, PA
    I've rehearsed the emergency drill of putting my gen2 Prius into neutral, but I will not test it above 42 mph. Anyone who has run one of the online planetary gear simulators recognizes that 42 mph is the critical speed at which one of the electric motors will red-line if the ICE is not revving. I am concerned that Toyota has put logic into the computer that prevents the car from going into neutral at some speed above 42 mph, to keep the electric motor from destroying itself. If true, it could help explain why some people in runaway situations can't get into neutral.
    Anyone know if this could be true?
  2. Lamboalex
    Lamboalex Hyper-Miler in training
    37
    Mooresville,NC
    I put mine into N at about 60mph earlier today
  3. NC_Prius
    NC_Prius Member
    186
    I had never heard that putting the Prius in neutral above 42 mph could harm the electric motor. So, on the way home this evening I put the car in neutral under various situations, all at highway speeds (65+ mph). I engaged cruise control and put the car in neutral. I accelerated using the cruise control and put the car in neutral. I accelerated manually with the pedal and put the car in neutral. I accelerated using both the cruise control and the pedal and put the car in neutral. No matter what I did, the car simply went into neutral. I would also like to know if the driver in San Diego attempted to put his car in neutral.
    I have had the Prius not switch to Drive or Reverse on the first try, though. In fact, this evening after I backed out of my parking spot I switched to drive to drive off. The car was still in reverse so I lurched backward.
    If my car is totaled from the neutral test, at least you have the published results. :) It seems to be running fine, though. I didn't keep it in neutral but for a brief moment each time.
  4. tumbleweed
    tumbleweed Senior Member
    4,067
    690
    Eastern Oregon
    I had my '05 Prius in Neutral at 70 or 75 MPH several times when I first got it. I didn't know about the issue of MG1 over speed and that was how I glided. Then I got around to reading some of the posts on here and quit doing it, didn't seem to hurt a thing though.
    I think if the engine is running when you put it in N it will keep running and there won't be a problem; but if you were on a very steep long hill and had it in N before you got to 41 MPH with the engine off and coasted up to a higher speed the over speed might occur.
  5. toyolover
    toyolover Member
    441
    67
    toronto, canada
    Bravo. You have covered almost all possibilities. I've tried to put it in N while driving -forgot what speed it was. I think it was at about 40-50 mph. The car did put itself in N and keep on gliding.
  6. fuzzy1
    10,332
    I also have shifted to N and R at highway speed (60) many times without problem. R is the fastest way to N (skipping the normal N delay) because the control logic is smart enough to know that you don't really want R when speeding forward. Even if it did try to shift, it has no physical gears or splines to grind, only some electric motor controls that ought to be designed to handle it without self-destruction.
    I also understand the MG1 overspeed risk to be a rare corner case, to be triggered only when going N at low speed with the ICE stationary, then rolling down steep hills to high speed where the ICE needs to spin to protect MG1. If an engine is surging, you are already out of this corner.
  7. donee
    donee New Member
    2,956
    197
    Chicagoland
    Hi All,
    The MG1 will overspeed above 42 mph, when the engine is at 0 RPM in a 1st Generation Prius. This same operational limit is set in the 2nd Generation Prius, although the MG1 speed rating is much greater. That is, rising above 42 mph, when running in EV mode below 42 mph, the engine comes on automatically, and MG1 slows.
    The warp-stealth engine speed is 1100 RPM. Go downhill in a Prius at any speed below the rated 105 mph with your foot off the gas pedal, and MG1 will not overspeed.
    The engine idle speed is about 900 RPM, nearly the same as the engine warp-stealth speed. The engine idle speed will be the speed the engine will run at, when the car is shifted to neutral, from a condition with the engine originally running.
    So, put the 2nd Generation Prius in neutral above 40 mph, with the engine running at idle rpm and MG1 will not overspeed, until well above 40 mph.
    In order to put MG1 in danger, one needs to slow down below 40 mph, so that the engine will drop out to 0 RPM, THEN shift into Netral (which locks the engine at 0 RPM), THEN proceed downhill for a long time on a steep hill, until the car is going well above 40 mph. I believe the commonly quoted speed for 10000 RPM rating of MG1 is 62 mph in the 2nd Generation Prius.
    So, as long as the engine is running, its highly unlikely you will overspeed MG1. And in an runaway engine situation, impossible.
    And as there is no mechanically stiff link between the engine and the drive wheels, even if the engine were to cease, the wheels would keep turning.
    This is a quick response. I am sure somebody else will fill in the exact detail.
  8. B. Roberts
    B. Roberts Hypah Milah! Ayuh.
    691
    212
    used to be "Glacial" Maine and now FL
    I tried this a few weeks ago to see if a "runaway" Prius could be controlled. Worked fine and I was travelling over 55 mph. Make sure that you push your shift lever over far enough to actually go into neutral.
  9. Boo
    Boo Boola Boola Member
    5,051
    488
    97
    Flushing, NY
  10. joewein
    joewein Driving in Japan
    35
    17
    Tokyo, Japan
    2013 Prius Alpha
    In the scenario you describe (accelerating through gravity beyond 42 MPH with the engine initially stopped), as MG2 speeds up proportionally with road speed, MG1 would keep accelerating the other way, as the MG1, MG2 and the engine are all connected to different shafts of the PSD planetary gears.
    42 MPH with the ICE at 0 RPM on the G2 corresponds to 6500 RPM on MG1, which is specified to survive 10,000 RPM, although it normally never exceeds 6500 RPM. So if the ICE remained completely stopped, things get critical for MG1 somewhere around 60 MPH.
    Once MG1 approaches its RPM limit, the control unit could limit its speed via drag (i.e. run it as a generator). Even with no fuel being injected and ignited that will have the effect of passively spinning the ICE from the counter-torque of the generator, which would let MG1 survive. If MG1 was not rev-limited (i.e. MG1 never acts as a generator in N) then MG1 damage could occur in this situation.
  11. dogfriend
    7,512
    1,188
    Carmichael, CA
    Carolyn shifts into N at 75 mph and then at 81 mph in this video:
    [ame=http://www.youtube.com/watch?v=II_03lbr-Jw]YouTube - Prius "runaway" unintended acceleration? Shift into neutral[/ame]
  12. Evilshin
    Evilshin Member
    119
    The MG1 can survive brief periods above 10,000 rpm, prolonged exposure would mean the back emf would damage the field coils and/or the battery charging system or the batteries themselves. However this can't happen in the shift to neutral scenario, since there is no power forward by the ICE or MG2 (probably power backwards from MG2), the back emf on MG1 would quickly bleed speed off of the car. Unless you were on a steep downhill.
    So San Diego dude should have shifted into neutral at speed, the car's regen would have kicked in by it's very nature. He would have slowed down. Also once in neutral, regardless of throttle position, the ICE would not have throttled higher, MG2 would not provide forward acceleration.
    But instead the dude hit the brakes, at 80mph +, it would take about two seconds on full throttle to heat the brakes up to: poof, no brakes...
  13. shiframb
    shiframb New Member
    New England
    From what the man said in the interview I saw, he was afraid to try to shift into neutral, because he was afraid in his panic, he'd accidently put it into reverse and he thought it would flip his car. He also said he was afraid to turn the car off because he didn't know if he would then be unable to steer-something he did not want to experience at 94 mph.
    If you've never had a situation like this happen, and have never tried these things in a "simulation/test", I can understand his fears. I wouldn't know what my car would do either. Imagine your mind racing and feeling like you were about to die-and try to think rationally.
    You can be sure I will be looking through this site, reading and then starting to practice emergency measures. If it happened to his 2008, it may happen to my 2007.
  14. patsparks
    10,664
    567
    Adelaide South Australia
  15. macmcrae
    macmcrae New Member
    dobitiv
    i find it odd that nowhere in any of the stories is the question asked "did you try to put your car in neutral?". You mean to tell me this guy was afraid for his life because his car was accelerating and that thought didn't cross his mind? Or that it did but he was afraid it would flip his car? Give me break. This whole thing stinks of manufactured outrage.
  16. Politburo
    Politburo Active Member
    971
    208
    While the "afraid to flip it" is plausible in some alternate reality, it really shouldn't be an excuse.
    We should all know how to operate our vehicles in an emergency. PERIOD.
  17. hobbit
    hobbit Senior Member
    4,089
    468
    Bahstahn
    A quick look at the nomograph shows safe MG1 spin speeds when the
    engine is idling around 1000 RPM. A little research before
    posting would have helped eliminate a lot of noise here.
    _H*
  18. Dozzer
    Dozzer Prius Noob
    189
    Swansea, UK
    I'll try the "unintended acceleration" argument next I pass a police patrol car over the limit.. just floor it..
    I tried the "P" button at 75mph yesterday.. goes into neutral in the blink of an eye!
    The news will be full of these bogus claims of the next few weeks...
  19. uart
    uart Senior Member
    4,220
    1,209
    Australia
    Very funny. :D
  20. qbee42
    qbee42 My other car is a boat
    18,058
    3,076
    Northern Michigan
    If you know that little about your car, you shouldn't be driving. We really need decent standards in this country for driver education.
    Tom
    3 people like this.
