Don't know if I should be excited or upset!
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Paul58, Aug 19, 2010.
  1. Paul58
    Paul58 Mileage Miser
    1,126
    125
    Atlanta
    Got home this afternoon and was so excited and proud of the fantastic 58.5 mpg displayed on the dash! After reading the posts here about tire pressure I figured I'd see where mine were at and maybe tweak them a little to squeeze a bit more out of a gallon of gas. You can imagine my surprise when I found the tire pressures ranging from 27.5 PSI to 31 PSI! My Prius is only two weeks old, and I've only put 300 miles on it so far, but I was shocked the dealer didn't check and adjust the tire pressure before delivering the car.
    So, I made my adjustments: 40 PSI in the front and 36 PSI in the rear, and hopefully will be able to improve upon the current 58 mpg I'm enjoying.
    Now, a question for the Chemical Engineers in the crowd... My Dealer Window Sticker showed I had the dealer installed option of Nitrogen in my tires (along with a couple BS applications). I added good ole Southern Georgia air! Will there be any ill effects by mixing Nitrogen and Atlanta air (with all it's various polluted particulates)?
  2. JimboPalmer
    12,470
    6,875
    Greenwood MS USA
    Air is 78% Nitrogen already, they will mix fine.
  3. Paul58
    1,126
    125
    Atlanta
    I knew I could count on someone to put my mind at ease! Thanks...
  4. almypal26
    almypal26 Member
    101
    So Cal
    As long as you stay child at heart.:D
  5. bagwell
    bagwell Active Member
    592
    49
    the woodlands, tx
    had my car a week and set all tires to 40psi = 60.5mpg on my 52 mile RT commute...average speed approx 50mph
  6. Paul58
    1,126
    125
    Atlanta
    Ahh so there's still hope!
    So, what is the Executive Package?
  7. cit1991
    cit1991 New Member
    289
    95
    Tulsa, OK
    ChE here. Air is fine. They use nitrogen in aircraft tires to save a few pounds (mass not psi). Aircraft tires contain much more gas, and a few pounds of weight savings is worth it.
    The overwhelmingly important thing is to keep them at the right pressures.
    The only precaution I take is to add air only when the compressor tank is cool (not right after running the compressor to pressure it up). That way, I add less water vapor.
    Also, when you do top them up, don't forget to reset the TPMS, so it can do its job.
  8. 2009Prius
    2009Prius A Wimpy DIYer
    2,705
    511
    63
    Would love to see a photo or scan of the sticker. Thanks! :)
