Door Controls?? :( Driver window works no locks no other window controls!!! HELPPPP!!!!!
Discussion in 'Gen 3 Prius Audio and Electronics' started by Its MEEEEEE!!!!, Jul 9, 2013.
  1. Its MEEEEEE!!!!
    Its MEEEEEE!!!! Junior Member
    24
    I need help i have a 2010 prius and my driver main controls dont work
    My driver window has no auto function but still rolls up and down but my door lock controls and all other window controls are completely non functional i dont know what to do!!!
    Also i dont really want to spend 300$ on a new panel please someone help
  2. rdgrimes
    rdgrimes Senior Member
    1,740
    448
    New Mexico, USA
    2018 Prius Prime
    Check the fuses.
  3. tach18k
    tach18k Member
    406
    38
    SoCal Beach Area
    check connector in door panel
  4. Its MEEEEEE!!!!
    24
    I pulled it off and apart n nothing the connector looks good and what fuses would i chevk??? I have my window working but nothing else from that panel thx guyd!!!
  5. rdgrimes
    1,740
    448
    New Mexico, USA
    2018 Prius Prime
    Your manual has info on both fuse boxes.
  6. Its MEEEEEE!!!!
    24
    Well fuses are good but i did notice when i roll my driver window up or down the light blinks...
  7. jdcollins5
    jdcollins5 Senior Member
    5,131
    1,342
    Wilmington, NC
    What light blinks? If dome light, check your 12V battery voltage.
  8. retired4999
    2,652
    625
    Eau Claire, Wi.
    jdcollins5,
    +1
    I will guess you are right! 12 volt battery.
  9. Its MEEEEEE!!!!
    24
    No not dome light the little green light on the switch blinks???
  10. phoenixgreg
    phoenixgreg Senior member
    1,157
    291
    66
    Phoenix
    So the each of the passenger's door controls work front and rear? I think you can restore the auto up and down feature for the driver's door by holding the up button until you hear a beep. Same for down.
  11. jdcollins5
    5,131
    1,342
    Wilmington, NC
    You have not hit the window control button have you? That will disable all windows except driver's.
  12. Its MEEEEEE!!!!
    24
    No i cant control any window but tge drivers also no door lock function from driver door the only button that works is my driver window and no auto just basic up and down
  13. jdcollins5
    5,131
    1,342
    Wilmington, NC
    Have you had the interior door panel off for any reason? Spilled any liquid on door control panel?
  14. Its MEEEEEE!!!!
    24
    Ive taken the switch panel out tp clean connections but never door panel and water has came in from the rain thar creeps in
  15. jdcollins5
    5,131
    1,342
    Wilmington, NC
    Have you checked the connections again since the problem started?
  16. Its MEEEEEE!!!!
    24
    Yeah just the connections to the swotches any more under the door panel??? I just think its weird how only one window switch works n nothing else lol are there any other control panels from other toyotas i can replace with??? The prius ones 300+ :-/
  17. jdcollins5
    5,131
    1,342
    Wilmington, NC
    Just curious, do all of the other door control panels work? Also, what made you check the connections the first time?
    I would call around to salvage yards and get a price from a wrecked Prius.
  18. tach18k
    tach18k Member
    406
    38
    SoCal Beach Area
    You should be able to replace the switches alone. Passenger door should match them if not at least function wise it would tell you if it was good or not, also you can manually check each switch function with a test probe
  19. phoenixgreg
    1,157
    291
    66
    Phoenix
    Look at page 98 of the manual and be absolutely sure you haven't accidentally pressed the WINDOW LOCK SWITCH which is located above the driver's PDL switch. This switch prevents children from operating their respective windows, but I'm not sure if it prevents the driver's window controls from working too. Maybe this one switch is defective and has stopped the other switches from working. Try pressing it on and off several times to be sure.
    It just seems odd that ALL the other door's window switches and the passenger door's PDL switch suddenly stopped working. I would think there's an overlooked fuse or fuses not set properly. Check again above the driver's foot-well at fuses # 6 (25A) for the PDL system and fuses # 15, 16,17 & 18 for each power window (25A). Check pages 468 and 469 of the manual for the exact locations. Unfortunately, these fuses are the "mini" style but there are some spares under the hood inside the outer panel located above the left wheel well.
  20. Its MEEEEEE!!!!
    24
    Yeah theres no wreckers that have prius out here in northern cali and the i pressed the window lock button a million times lol but the windows all work its just the driver panel that wont control anything but driver window i only checked my connections after the problem started ughhh i guess im stuck replacing then anyone selling a panel??/ haha
