door panels
Discussion in 'Gen 3 Prius Accessories and Modifications' started by Jeff'sPrius, Sep 19, 2009.
  1. Jeff'sPrius
    Jeff'sPrius New Member
    Washington
    Has anyone removed the door panels from a 2010 prius V?
  2. MikeDS
    MikeDS Member
    298
    Los Angeles
    Check the Audio subfourum, lots of pics...
  3. radioprius1
    radioprius1 Climate Conspirisist
    1,355
    155
    Iceland
    Yeah look for the thread about "removing 6x9s" there are several members (me included) who removed their doors and took photos.
    Quick rundown: There are two screws. First one is positioned vertically in the door pull. Just use a flathead screwdriver to remove the little padding in there then a philips to remove the screw. Next screw is behind the door latch and oriented horizontally. Use a flathead to pop out the piece of plastic, then a philips to get the screw out. Then pull the door off, start pulling on the side of the door by the kick panel. It comes right off!
