Drain stale gas
Discussion in 'Gen 2 Prius Main Forum' started by Dee Quick, Feb 9, 2018.
  1. Dee Quick
    Dee Quick New Member
    Los Angeles
    I want to drain the stale gas out of my gas tank. I am new to this forum. Please point me in the right direction. Thanks, DQ
  2. Kevin_Denver
    Kevin_Denver Active Member
    581
    425
    Denver, CO
    There's no drain plug on the 2nd gens due to the bladder that's used on the fuel tank. The easiest way to drain gas is to unhook a fuel line under the hood and then one way or another, feed voltage to the fuel pump to get it out (need to purchase wiring diagram). I don't believe it's possible to put a line into the tank via where you'd normally fill as I think there's a screen. Only other option is to drop the tank out of the car.
    That being said, the fuel bladder on the Prius is incredibly good at not letting air in or out, which should significantly extend the life of gasoline in the tank. How old is the fuel in the car? The normal shelf life of gas is 6 months, but will probably be okay for 2x that in the Prius due the bladder. You might very well be okay with just filling the car up with Premium and using the gas that's in it (octane rating of gas drops over time, so Premium will help equalize it).
    Raytheeagle and Mendel Leisk like this.
  3. fotomoto
    fotomoto Senior Member
    5,632
    3,805
    So. Texas
    More info needed.
    Raytheeagle likes this.
