Driver Side Window and Door Panel
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by TopJimmy5150, Oct 22, 2009.
  1. TopJimmy5150
    TopJimmy5150 Junior Member
    55
    Gillett, PA
    Can any of you check this out on your GIII Prius?
    I have long legs so my left knee is usually resting on the (interior) door panel when I'm driving. When I roll up the window all the way, the interior door panel seems to move inward when the window gets to where it is all the way up. It doesn't seem quite right. I haven't had a chance to check out the passenger side. Anyone else experience this? Do I have my first warranty issue???
    Thanks,
    -Jay
  2. Bobsprius
    Bobsprius BobPrius
    679
    Buffalo
    In my Current Prius Gen III - V, and in 2 prior cars (not Prius) I have always noticed the little push when the window hit's the closed position. It's part of the mechanics of the design. The window closes closer to the door jamb thus you get the little push into the door panel/frame of the door. I only detect it as well, when something like my knee is resting close to the door.
    I think your OKand there is no issue. :)
  3. mgb4tim
    mgb4tim Noob
    1,153
    111
    Pittsburgh, PA
    Many cars have the same issue.
  4. TopJimmy5150
    55
    Gillett, PA
    Good to know! Thanks!
  5. chrisj428
    chrisj428 Active Member
    680
    144
    35
    Vernon Hills, IL
    Mine does the same (as have other cars I've owned). It's not concerning to me.
