Drivers side kick panel, fastener cover?
Discussion in 'Gen 2 Prius Main Forum' started by Priusmeus, Mar 5, 2008.
  1. Priusmeus
    Priusmeus New Member
    Upstate, NY
    New 2008. On the Drivers side front kick panel (left of parking brake), I can see a recessed but clearly visible threaded fastener. It looks like perhaps this is supposed to have a plastic cap covering the fastener.
    Can anyone confirm if there is supposed to be a plastic cap over this or if it is normal for the recessed fastener to be exposed?
    Thank you
  2. seasalsa
    seasalsa Active Member
    1,278
    Kent, WA
    Mine is exposed and came that way. I noticed it when I first got the car.
    Guess it is normal.
  3. Tideland Prius
    16,408
    Nope, it's exposed :(
  4. Qlara
    Qlara New Member
    488
    Normal.
    Mine also has a screw stud sticking out from that kick panel as well.
    This screw seems to be bolted outside-in to the chassis, and Totoya just uses the stud acting like a panel fastener. Efficient design, but they should have made it easier to the eyes too. (Cover the stud at least.)
  5. Priusmeus
    Upstate, NY
    Thank you all for your responses! I had discovered it about a week after picking up the car when installing the Weather Tech Extreme Duty Floor Liners. It just didn't seem like Toyota would intentionally leave it exposed so I thought I would present it to PriusChat instead of checking with the dealer on something like this.
    ~ Sharon
