Driver's Side Window Problems
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Tobalt, Jun 26, 2006.
  1. Tobalt
    Tobalt New Member
    47
    Huntsville, AL
    I've noticed this for a short while now. At first, it wasn't a big deal, but I'm at the point where I want to fix it.
    When I set the window to auto-up, when it hits the top it makes a small mechanical squeal. It sounds like the motor is moving the window past the limit. With the window fully closed, if I click the button to auto-up, it makes the same squeal. Any suggestions?
  2. tumbleweed
    tumbleweed Senior Member
    4,067
    690
    Eastern Oregon
    I have never tried to work on my own power windows so if it were me I would take it in and have it fixed if it's still under warranty, if not I would at least get an estimate.
    I had one in another vehicle that burned out a motor because it was maladjusted, if I had gotten it adjusted it would have saved me some money.
  3. Marlin
    Marlin New Member
    1,407
    Bucks County, PA
    <div class='quotetop'>QUOTE(Tobalt @ Jun 26 2006, 09:54 AM) [snapback]276786[/snapback]</div>
    I know this post is a little old now, but...
    Look in the owners manual for the instructions on how to calibrate the auto window.
  4. tumbleweed
    4,067
    690
    Eastern Oregon
    <div class='quotetop'>QUOTE(Marlin @ Jul 5 2006, 04:43 AM) [snapback]281329[/snapback]</div>
    Your answer is better than mine Marlin, that sounds exactly like what he needs to do. Sometimes I go back and try to find good questions that should have been answered but weren't, hope Tobalt sees your answer.
  5. Tobalt
    Tobalt New Member
    47
    Huntsville, AL
    <div class='quotetop'>QUOTE(Marlin @ Jul 5 2006, 06:43 AM) [snapback]281329[/snapback]</div>
    I'm looking at the manual, and the only calibration I can see for the window is a cal needed to be done if the autoup/down doesn't work. Not the problem in my case. I think my window might be misaligned; I'll check it out with the dealer.
  6. haceaton
    haceaton New Member
    27
  7. hdrygas
    hdrygas New Member
    3,650
    Olympia Wa
    Mine has always made a little bit of noise going up? I have never had the auxiliary battery go dead, off or anything! I guess I should try the "recallabrate" thing
