driving in the rain
Discussion in 'Gen 2 Prius Technical Discussion' started by williab, Sep 1, 2007.
  1. williab
    williab New Member
    Been bragging about my week old Prius and several people who know people who have them said that they have problems driving in the rain,wet roads - slipping , hard to control - ???????? what's up with that ????? if true, how do you compensate for it ??????? I do plan on getting snow tires of some sort but rain ????? Any info is appreciated
  2. apriusfan
    apriusfan New Member
    6,050
    205
    S.F. Bay Area
    <div class='quotetop'>QUOTE(pie r sqd @ Sep 1 2007, 04:45 PM) [snapback]505567[/snapback]</div>
    Sounds like urban legend (about problems in the rain).
    If the problems are in fact true, I would check the circumstances in which the problems occurred: bald tires???; starting off on an oily surface???; stability control disconnected???? I think you get the point.
    Net, net, with the safety systems on the Prius, there would have to be some external factor for there to be problems.
  3. David Beale
    David Beale Senior Member
    5,963
    1,985
    Edmonton Alberta
    I think some people are just a little too harsh on cars. Yes, it's not a race car. My car does just fine in the rain. I haven't slid or spun the tires or tripped the traction control or antilock enough to cause me problems so far. On the so called "garbage" stock Goodyear Integrities.
    I think the comments were caused by the 2005 and earlier traction control being too sensitive, and ill-informed owners not realizing they were trying to accelerate on oil soaked roads. One that was discussed here complained they would spin the tires and activate the traction control aggressively exiting a parking garage. Just where you would expect lots of oil on a concrete road. Worst case scenario.
  4. Bobwho
    Bobwho New Member
    68
    Chicago area
    <div class='quotetop'>QUOTE(David Beale @ Sep 1 2007, 08:20 PM) [snapback]505604[/snapback]</div>
    I do not know about anyone else but both my daughter and I own Prius and when we went to get new tires the traction and wet handling improved markedly.
    Moral: OEM rubber is the cheapest thing they can get. If you do not like the wet handling of your car get rid of the OEM rubber and buy decent tires to replace them.
  5. williab
    williab New Member
    <div class='quotetop'>QUOTE(Bobwho @ Sep 1 2007, 09:41 PM) [snapback]505607[/snapback]</div>
    Any suggestions for tire brands - regular or snow - from other threads I have read in the last few weeks, no one seems to like the standard tires - thanks for the help
  6. apriusfan
    6,050
    205
    S.F. Bay Area
    <div class='quotetop'>QUOTE(pie r sqd @ Sep 1 2007, 07:07 PM) [snapback]505619[/snapback]</div>
    Here is one vote for Michelin.
  7. qbee42
    qbee42 My other car is a boat
    18,058
    3,076
    Northern Michigan
    The OEM tires are crap. That's where all of the rain and snow horror stories originate. I swapped mine for Micheline MXV4+ Energy LRR all-season radials. The difference in control was like night and day, with no loss in fuel economy.
    Tom
  8. PearlDriver
    PearlDriver Junior Member
    76
    Snohomish, WA
    I've had my Prius for less than five weeks and have only had one really rainy, windy day. My commute that day included crossing a high bridge with severe crosswinds. My only complaint is that my mileage for that trip dropped by over 3 MPG from a normal commute of 54-55 to 51.5. I guess the extra resistance and the wipers were just too much. :lol:
    In similar situations my Chevy Aveo was hard to control and I was worn out by the time I got home.
  9. patsparks
    10,664
    567
    Adelaide South Australia
    OEM tyres in Australia are Michelin and they seem very good.
    The traction control is a little easy to set off in my 04 but maybe that's because there's a lot of torque to spin the wheels.
    Even though I sometimes upset the traction control I have never felt that the car is out of control, with ABS and traction control how can you get into trouble?
  10. hyo silver
    hyo silver Awaaaaay
    15,260
    1,598
    off into the sunset
    <div class='quotetop'>QUOTE(pie r sqd @ 2007 Sep 1 4:45 PM) [snapback]505567[/snapback]</div>
    It's not the car's fault, it's the tires. Just about anything would be an improvement.
    By the way, pie are round. :)
  11. patsparks
    10,664
    567
    Adelaide's favorite pies, Balfours meat pies are square.
  12. David Beale
    5,963
    1,985
    Edmonton Alberta
    Well, in New York weather (where the OP is), I would recommend Nokian WR tires. You will be able to use them all year round, as they are true all season tires, and have the snowflake symbol on the sidewall, meaning you do not have to "chain up" on interstates like other all season tired vehicles must in certain situations.
    I'm putting them on Pearl asap, as we have six month winters here. They work well on ice and snow, are great rain tires, and wear very well, even on hot dry summer roads. They are not cheap, however. You do get what you pay for.
  13. paprius4030
    paprius4030 My first Prius
    2,077
    296
    York,Pa.
    When it's raining........Slow down!! and don't drive like an idiot....Same as with any other car.
  14. dhancock
    dhancock 2 Prius Family
    357
    40
    Hamburg, NY (Buffalo area)
    I'm a relatively new owner (but now have 10Kmiles). I've noticed a greater tendency to spin with the stock tires too. I attribute it to the higher low speed torque that you have with electric motors, more than anything else. I'ts no big deal though as between the traction control and more linear gas (? is that the correct term?) pedal action it is easy to control.
  15. williab
    williab New Member
    <div class='quotetop'>QUOTE(hyo silver @ Sep 2 2007, 11:19 AM) [snapback]505842[/snapback]</div>
    I guess the general opinion is the tires suck - will stick it out for fall and get snows and then change in spring - if pi is not sqd in my class you fail -
  16. samiam
    samiam Antipodean Prius Poster
    2,442
    29
    Enn Zed
    Just been through one of the wettest winters on record here. Not even one occasion of loss of traction, no wheel spin, no problems.
  17. tochatihu
    tochatihu Senior Member
    9,457
    3,656
    Kunming Yunnan China
    2001 Prius
    Whatever tires or chosen inflation pressures, on this topic I always like to nag.
    The wet traction decreases rapidly when tread depth is below 3 mm (well above the legal wear bar limit). It may not be to your best advantage to get those last few thousand miles out of any set of tires.
  18. Tchou
    Tchou Member
    161
    <div class='quotetop'>QUOTE(pie r sqd @ Sep 2 2007, 12:45 AM) [snapback]505567[/snapback]</div>
    One good reason would be that they may have over inflated their tyres, Lot of people advice here to inflate more than the Toyota Recommended value to increase MPG, they do gain MPG and Grip on a dry road, but the drawback is that the grip is lost on wet road... The Toyota given value is the average value for both dry and wet road good handling...
  19. Tchou
    Tchou Member
    161
  20. seasalsa
    seasalsa Active Member
    1,278
    Kent, WA
    Of course it don't rain much around here but I have 57,000 miles on OEM tires (2 Sets) and have never had trouble driving in the rain or snow.
