dumb question
Discussion in 'Prius c Main Forum' started by xerox6135, Apr 22, 2012.
  1. xerox6135
    xerox6135 Member
    170
    93
    michigan
    How do you check the oil in the transmission of the prius c:confused:
  2. ewaboy
    ewaboy Active Member
    693
    205
    Hawaii
    Not a dumb question - at least not to me cause I'd like to know if a CVT transmission is sealed. Can the CVT be checked, or needs to be checked, for fluid level between service intervals.
  3. JimboPalmer
    12,470
    6,875
    Greenwood MS USA
    Toyota suggests you inspect it every 30,000 miles, they never suggest you replace the WS ATF.
    http://www.toyota.com/t3Portal/document/omms/T-MMS-12PriusC/pdf/2012_Toyota_Prius_C_WMG.pdf
    Owners of previous models suggest you replace it at 30,000 miles then every 60,000 miles after that.
    Again in previous models, there are drain and fill plugs, to inspect you open the fill plug and be sure it is full to edge of the plug.
    I bet the details vary on the c.
    http://www.greencarcongress.com/2012/02/priusc-20120208.html
    3 people like this.
  4. David Beale
    David Beale Senior Member
    5,963
    1,985
    Edmonton Alberta
    Just like differentials.
  5. priusCpilot
    priusCpilot Active Member
    663
    210
    LA
    Are there separate oil for the differential in all Prius tranaxles?
  6. formula
    formula Member
    320
    32
    CA
    what kind of oil is it? need to get from toyota?
  7. David Beale
    5,963
    1,985
    Edmonton Alberta
    Special oil due to the fact it immerses motor generators so must withstand "high" voltage. Toyota only. BTW, the same applies to the refrigerant used in the A/C system. Special oil in there too as it immerses the "high" voltage pump.
    The diff. is in there with everything else, and uses the same oil.
    There is some evidence the HSD oil is stressed and that taking care of it is a "good idea". Change it out at 30,000 mi. Cheap insurance. I was quoted $100 to change it by a dealer. The oil costs around $30. Lots of members do it themselves.
  8. justlurkin
    justlurkin Señor Member
    499
    63
    Long Island, NY
    The Prius c uses the same Toyota WS transmission fluid ("WS" = world standard) as the Gen-II and Gen-III Prii.
    3.5 quarts according to the Prius c manual.
    It's a good idea to do the first drain-and-fill at 30,000 miles to get rid of all the metal shavings that comes from the normal wearing-in process of the gears, and the dissolved metals.
    Hope this helps!
  9. usnavystgc
    3,159
    990
    Tucson, AZ
    I don't know if this will help but take a look at it to see what it's worth. It may help and it may not. Gen1 Prius Transaxle Service
    I def agree w/ changing it at 30k and 60k thereafter. In my mind, its cheap insurance.
