Dynamat 2.0
Discussion in 'Gen 3 Prius Accessories and Modifications' started by phoenixgreg, Oct 8, 2012.
  1. phoenixgreg
    phoenixgreg Senior member
    1,157
    291
    66
    Phoenix
    After $500 in materials and many days to do the whole interior including the doors, I’d give Dynamat a C+ on sound deadening. I’m particular and didn’t get that “wow” difference once I had it all installed, but others who ride in my car did think it is much better.
    The material has its hazards. The foil backing is as sharp as razor blades and can slice fingers and thumbs while working it. Also, you need lacquer thinner to clean any of the tar that gets on tools or you. A person would have to be confident and able to remove most of the lower interiors including door panels, consoles, seats and carpet to get access to the metal floor-pan.
    Now I’m wondering if somehow doing the wheel wells in Dynamat would deaden the tire noise that transfers into the cabin – especially at higher speeds or on rougher roads. If Dynamat made a product specifically for this, I’d give it a shot. No shinny foil backing…it would have to be flat black to blend in.
    Anyway, here are some pics (not shown is the spare tire compartment and above the rear wheels (but they are also done with Dynamat) :
    engerysaver, EdyJun and sfv41901 like this.
  2. mrstop
    mrstop PWR Mode
    742
    329
    109
    Cincinnati, OH
  3. phoenixgreg
    1,157
    291
    66
    Phoenix
    Thanks for the links...I had seen the speaker one before. No matter which approach is taken, it's a lot of work! I did get some improvement using my method...maybe I should have found a shop to do it professionally, but it's hard to see what is being done and once completed; the product is invisible. I still think more can be gained from treating the wheel wells. Here is one of my doors:
  4. SuperchargedMR2
    SuperchargedMR2 Diehard Rams Fan
    673
    179
    Vancouver, WA
    I've never covered the entire area with Fynamat. You can get the same performance & sound deadening by just using pieces of Dynamat. I got excellent results on my 09 Corolla S but covering the trunk & doors in this same method.
  5. sfv41901
    sfv41901 Masta S
    4,591
    5,293
    Palmdale, Ca
    Wow, u really went to town. I bet if u were able to get the fire wall done that would help a lot.
  6. phoenixgreg
    1,157
    291
    66
    Phoenix
    Yes, the upper firewall is nearly impossible to reach short of pulling everything under the dash. BTW, that's almost 1/4 of the car! My next phase is to line the wheel-wells with it. I still think at high speeds, I can hear some tire noise. I don't think anyone here has tried that, but I'll post pics and results when done.
  7. phoenixgreg
    1,157
    291
    66
    Phoenix
    jonasetb likes this.
  8. mnml
    mnml Ain't nobody got time for that.
    377
    161
    Ladera Ranch, CA
    you are obsessed! :LOL: that some serious matting.
  9. Mistah Ya
    Mistah Ya Junior Member
    58
    Phnom Penh
    I'm ready to do it also but I live in Phnom Penh, Cambodia, it's difficult to find dynamat, hushmat, and the likes... hate to order from the state. Will spend my weekend looking for materials
  10. Sfcyclist
    Sfcyclist Senior Member
    1,621
    375
    SF, CA
    C+, oh wow.. thanks for sharing. I read best results seem to come from insulating doors.
  11. 06d
    06d Junior Member
    Bay area
    i did the doors, i have to admit it does give a good *thump* sound when your closing the door(kind of like a lexus). unlock the cheap metal *klunk* w/o it otherwise i agree its a c+ [​IMG]
  12. markdjr
    markdjr Junior Member
    Since your clearly willing to go the extra mile, I'd try and tackle the glass if you're up for another challenge. If you could find, or have made some insulated glass I think you'd get the "wow" you're looking for. Regardless, job well done, nice attention to detail.
    phoenixgreg likes this.
  13. phoenixgreg
    1,157
    291
    66
    Phoenix
    I think my next step would be better tires and that will be many more miles down the road. In the mean time, it is one of the quieter Prii.
  14. KK6PD
    KK6PD _ . _ . / _ _ . _
    4,003
    946
    118
    Los Angeles Foothills
    Most impressive!
    A+ job in installing with the coverage you achieved!
    Did you also do the rear tire well in the trunk? I find that in my GEN II a big source of noise!
    How much weight did all the mat add to the car?
    I have been wanting to do this myself, it is a lot of tear out, but that's how you get good results.
    I am surprised you initially gave it only the C+! Your coverage pattern is pretty good!
  15. phoenixgreg
    1,157
    291
    66
    Phoenix
    KK6PD: Yes, I did the inside and outside of the rear wheel wells. Each had its challenges. There's a gas line cover (plastic) that needs to come off to get the Dynamat behind it. It does snap back in - can't recall if there was a bolt or not. As far as the insides, you have to extract both sides of the plastic wheel well shrouds to gain access and there's allot of wiring going on to get around. You asked how much it all weighs and if I figure in 4 doors, the floor and the wheel wells it comes out to about 60 pounds or the additional weight of child passenger. I have not noticed a significant drop in mileage.
    As for my "C+", it does deaden the road noise to a degree, but don't expect a "Cadillac quiet" ride from this mod. You can still hear tire noise just not as much of it. If I were to be able to go back in time before the floor and wheel wells, I'd have gotten a complete set of Michelin Primacy tires for the same money. The mod cost about $600. Oh yes, I also did the "trunk" area beneath the spare.
    KK6PD likes this.
  16. Spaz
    Spaz Junior Member
    82
    25
    New Jersey
    Have you tried playing with mass loaded vinyl? I was going to try a similar treatment to my wheel wells with the mlv
  17. phoenixgreg
    1,157
    291
    66
    Phoenix
    I've seen another thread here where a member tried that. I don't recall what he said about the noise-dampening though.
  18. Spaz
    Spaz Junior Member
    82
    25
    New Jersey
    I did the interior of mine with mlv and was definitely happy with the results. I'd say it ateast cut the noise in half and it was way less then the 500 you spent on dynamat. I was just wondering if you played with that material...I definitely have to do some treatment like you did here tho
  19. KK6PD
    4,003
    946
    118
    Cool, thanks for the info!
    Nice Job!!!
  20. engerysaver
    engerysaver Real Senior Member
    426
    130
    Tyler, Texas ; USA
    Great pictures;(y) good job;(y) I used Roadkill Sound Damping material on my Prius, for about half the price of Dynamat.
    It works just as good, cutting road noise down by about 1/2 .;)
    :( I wish Toyota had more sound proofing in the Prius!!
