E3 spark plugs
Discussion in 'Gen 2 Prius Technical Discussion' started by s3nfo, Jan 10, 2011.
  1. s3nfo
    s3nfo Member
    164
    24
    San Diego, Ca
    Has anybody tried E3 spark plugs in a Gen II?
    What did you think?
  2. TommyV72
    TommyV72 New Member
    Denver, Colorado
    I have never been impressed with those E3 plugs, also I have not seen any real change with them installed. I wouldn't waste the money.
  3. ivanbg
    ivanbg Junior Member
    Alexandria VA
    I would stick with stock spark plugs. If you really want to save fuel and get the most performance form a single bang then get the most expensive ones Toyota recommends for your vehicle.
  4. David Beale
    David Beale Senior Member
    5,963
    1,989
    Edmonton Alberta
    The stock plugs are the best made and best functioning spark plugs, in my experience. They are used by racers as well (obviously in different heat ranges and different sizes in various engines).
    This is why they don't need to be changed until you go 60,000 mi (100,000 km). The downside of leaving them in that long is they can corrode in place and be very difficult to remove. I advise loosening and re-tightening them every 20,000 mi (35,000 km). Do be careful though. You should know how to avoid damaging them or the block. If you are worried about your skills in this area, get a Toyota mechanic to check them for you.
  5. covrc
    covrc Junior Member
    Newburyport MA
    We stayed with stock plugs too.
  6. snead_c
    snead_c Jam Ma's Car
    667
    58
    Hendersonville
    No real payback (performance or FE) with exotic plugs. Just use standard spec ones.;)
  7. s3nfo
    s3nfo Member
    164
    24
    San Diego, Ca
    And I did. Went with the NGK spec plugs.
  8. Onesysofadown
    Onesysofadown New Member
    West Chester, PA
    Don't bother, stick to stock or comparable iridium. Was worried about my plugs getting seized so at 39,000 had them swapped. Don't know if they were defective or if they were improperly installed, but car began to misfire on 4th cylinder. So after $85 tow and dealership charging me $75 to reinstall original plugs, I regret ever having them swapped. Should have listened to that old saying that if it is not broken, do not fix it!
  9. snead_c
    667
    58
    Hendersonville
    I couldn't resist posting how your comment on the "old saying" was one I often used on my deceased father who loved to tinker on cars...even when they ran perfectly. After his last biggy on a fuel injection system that he knew nothing about he spent several hundred dollars to repair his "improvements" :rolleyes:
    At least his heart was in the right place ;)
  10. cvec7
    cvec7 New Member
    Anchorage, Alaska
    I use NGK BR9EIX plugs in my Gen II Prius. They've been working great. No issues yet.
  11. Oldwolf
    Oldwolf Prius Enthusiast
    826
    110
    NC
    2016 Prius v wagon
    Don't forget to use antiseize on threads. Since the engine has an aluminum head this is necessary.
  12. A J
    A J Junior Member
    29
    Lillian Al
    Everything I have ever read about these plugs on/in any forum/mag, tells me to stay away from them. a new E3 in comparison to one that has a few miles on it is like night and day
  13. snead_c
    667
    58
    Hendersonville
    Right.
    If they really made any worthwhile improvement in performance or economy I am confident Toyota and other manufacturers would snap them up to raise their EPA figures as well as test track numbers.
  14. Simtronic
    Simtronic Active Member
    290
    116
    Surrey, UK
    2017 Prius PHV
    Business Ed. Plus
    I use Denso ik16's this type of Iridium plug are used as standard on the later gen 3s though probably a different number.
