Easy Tar removal
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by justin96039, Jul 25, 2006.
  1. justin96039
    justin96039 210,000 Miles on our Prius!
    29
    Valencia CA
    If you have tar on your car, use some baking soda, yes any brand. Make some paste with a little bit of water and it comes right off. Its best to do before you wash the vehicle. I am however not accepting any liablity for any damage, if any should occur. I have used this on my white vehicles with no problem. Never had another vehicle to try it on. Maybe its like sand and helps get rid of it, but you barely have to do any rubbing. Possibly neutralizes the acids in the tar. Im sure its not as harmful as other products sold out there. JW
    Let me know what you think and if you try it. It makes it so much easier!
  2. hwalker911
    hwalker911 New Member
    84
    Piedmont of North Carolina
    <div class='quotetop'>QUOTE(JWHybrid @ Jul 25 2006, 01:23 AM) [snapback]291849[/snapback]</div>
    You can also use WD40, easy on and easy off...no risk of damage to the paint. :blink:
    Happy Motoring
  3. Dan-Wolfe
    Dan-Wolfe Member
    166
    31
    North Canton, Stark, Ohio, USA
    <div class='quotetop'>QUOTE(hwalker911 @ Jul 25 2006, 07:36 AM) [snapback]291883[/snapback]</div>
    What about bugs? What gets rid of those pesky things?
    Dan
  4. eagle33199
    eagle33199 Platinum Member
    5,122
    268
    2015 Prius v wagon
    or more importantly, how about tree sap? My sister's civic got a ton of tree sap on it last year, and it's been hell trying to get that stuff off.
  5. glenhead
    glenhead New Member
    166
    <div class='quotetop'>QUOTE(eagle33199 @ Jul 25 2006, 08:46 AM) [snapback]291920[/snapback]</div>
    Try GooGone - it'll cut through most organic sticky stuff.
    For bug guts/chunks, if you don't want to scrape it with a fingernail or a nylon dish sponge thingy, drape a soaked towel over the area (with the car in the shade so it doesn't cook), leave it for "a while" to soften them, and they'll usually wipe right off. Just be sure the towel is in contact with said guts/chunks. You can also do what I do, and ignore them 'till the next big rainstorm...
    The WD40 works well on tar, but so does kerosene or diesel fuel on a toothbrush, followed by soap and water. (Gasoline cuts it faster than almost anything, but it's not as safe. Insert normal disclaimers here...)
  6. eagle33199
    5,122
    268
    2015 Prius v wagon
    <div class='quotetop'>QUOTE(glenhead @ Jul 25 2006, 09:11 AM) [snapback]291933[/snapback]</div>
    Unfortunately, it hasn't been much help on the tree sap... it was better than anything else we tried, though.
  7. Charles Suitt
    Charles Suitt Senior Member
    1,637
    17
    Dallas TX
    :( I believe baking soda is an abrasive. That being the case, its use in removing anything from the Prius paint would scratch the surface of the finish. Might be fine scratches, but over time could be damaging to that "showroom shine."
  8. Tideland Prius
    16,402
    someone on this board told me peanut butter and it works quite well.
  9. Bill Merchant
    Bill Merchant absit invidia
    4,096
    85
    I remove stubborn tar or sap with lighter fluid (naptha). It's easy to find. Just wet a small spot on a paper towel and GENTLY wipe at the goo, changing the position of the paper towel frequently. If it's a big blob, spray a little directly on and wipe with a paper towel. DO NOT THROW THE PAPER TOWELS IN THE TRASH! They might spontaneously combust. Just let them sit out in the air for a couple of hours until they are dry.
    Yes, I know this causes VOC air polution, but so do the fir trees that drop their sap on my Silver Cloud. Baking soda is too abrasive. I don't want to use a strong detergent and remove the finish with the goo.
  10. Alnilam
    Alnilam The One in the Middle
    760
    Carlsbad, CA
    <div class='quotetop'>QUOTE(Tideland Prius @ Jul 25 2006, 10:00 PM) [snapback]292426[/snapback]</div>
    But now the bugs are back again........
  11. Tideland Prius
    16,402
  12. hwalker911
    84
    Drive slower, and the bugs will wind surf right over the Prius... B)
  13. Trollbait
    12,240
    If it was on your skin, rubbing alcohol will take off sap, and cooking oil will get the tar.
    You probably want to use the wet towel method to help soften even hardened sap. You should get sap off as soon as possible. As it hardens, it shrinks, and could possibly pull the paint up over time.
    Is bug and tar remover safe? IIRC the main ingredient is xylene.
