1. ServoScanMan
    ServoScanMan Member
    262
    Lorena, TX
    What's an ECU update? I'm assuming it for updating the firmware in the Engine Control Unit. But, you know what they say about those that assume....that's why I'm asking. Just to be sure I understand. Thanks!
  2. seasalsa
    seasalsa Active Member
    1,278
    Kent, WA
    <div class='quotetop'>QUOTE(ServoScanMan @ Apr 28 2006, 12:45 PM) [snapback]246803[/snapback]</div>
    Did you just get your recall notice? SC-50P was issued to reflash the ECU that was suposedly causing a stalling problem in some Prius. I had mine done in November. A search will provide more info.
  3. Charles Suitt
    Charles Suitt Senior Member
    1,637
    17
    Dallas TX
    <_< ECU = Engine Control Unit - one of the MANY "computers" in the Prius.
  4. ServoScanMan
    ServoScanMan Member
    262
    Lorena, TX
    <div class='quotetop'>QUOTE(seasalsa @ Apr 28 2006, 03:06 PM) [snapback]246811[/snapback]</div>
    I just bought the 2006 Prius a couple of weeks ago. I only live 10 miles from work. When I pull into the parking lot at work I am going less than 10mph. The MFD (Multi-Function Display?) shows the battery applying power to the wheels and the ICE does not have any power flow. But, I can hear the ICE running. I don't think this is correct, that is why I asking about the ECU. Should I tell my dealer about this -or- is this normal?
  5. qbee42
    qbee42 My other car is a boat
    18,058
    3,076
    Northern Michigan
    <div class='quotetop'>QUOTE(ServoScanMan @ Apr 28 2006, 08:23 PM) [snapback]246916[/snapback]</div>
    The ICE is not running if the MFD shows no power flow. Are you sure the ICE is actually running? It could be motor or fan noise. It is also possible the ICE is being spun without gas to burn excess battery charge. This doesn't happen often, but after a long downhill with lots of regen, the battery can charge to its limit and the computer will spin the ICE just to use up energy.
    Tom
