eCVT Concern
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by MNTech, Nov 19, 2013.
  1. MNTech
    MNTech Junior Member
    24
    Is it possible to feel a prius shift? There have been times I can feel it shift when going from 0-60 mph. There's only one shift, if any. This doesn't happen on a regular basis, but have felt a light shift maybe 3 or 4 times now. Is this normal?
  2. uart
    uart Senior Member
    4,220
    1,209
    Australia
    Yes I've noticed that too. It's a CVT but it does seem to have preferred operating points programmed into it.
    Another thing that people sometimes find a little unnerving is that in the first minute or so of driving (when the engine is just warming up) it can have a really abrupt jump in engine revs without any corresponding change in speed or power demand, especially if you're going up a hill. Some people even come here insisting that their "clutch" was slipping. LOL :LOL:
    That one is caused by the cats reaching a temperature threshold where the ECU is suddenly willing to give a lot more engine power, so there's a sudden shift from predominately electric to predominantly engine power.
  3. Britprius
    Britprius Senior Member
    5,194
    1,917
    Herefordshire England
    As Uart said this feeling is normal, but in practice the Prius does not shift at all. Not even for reverse neutral or park. The feeling of gear shift is a speed juggling act between the engine and and the motor generators, controlled by the cars computer. Go to the link below and play with the slider to see how the engine or electric motors affect the car speed without any mechanical change of gear ratio.
    Toyota Prius - Power Split Device
    John (Britprius)
  4. nh7o
    nh7o Off grid since 1980
    1,686
    340
    Hawaii
    There is a slight transient in torque when going above 42 mph while coasting downhill or in EV mode. The ICE is spun up to avoid over revving MG1. There is no fuel used, the engine is only freewheeling, but the torque pulse required to make this happen is easy to feel.
  5. MNTech
    24
    Thanks for responses! Wanted to make sure my transmission wasn't showing signs of failure. It does have 223K miles. Have never fully understood how the CVT works, the slider was quite helpfull John!
  6. edthefox5
    edthefox5 Senior Member
    10,096
    4,829
    Clearwater, Florida
    How many times have you changed the transmission fluid?
  7. MNTech
    24
    Changed it for the first time last week, but I'm not the first owner. The color was black!
