Electric/Computer Problems With My 2010 Prius
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by szimmo, Jun 12, 2012.
  1. szimmo
    szimmo Junior Member
    Santa Monica
    I own two Prius (2007 and 2010) and have been satisfied. . .But I have developed two problems with the 2010 recently:
    1) the car starts, but I can't shift into drive--the shift handle moves but it won't shift the electronics into drive; it remains in park. After starting/stopping it a couple of times, I can shift into drive. Then several weeks later the problem starts up again.
    2) the both rear windows go down on the their own.
    I know both of the above sound goofy. But anybody out there with any of the same problems? Any words of advice?
    P.S. I of course went to the dealer and of course the dealer said that they could find nothing wrong.
    Thanks,
    Confused in Santa Monica
  2. Paradox
    29,110
    8,591
    201
    2014 Prius v wagon
    moved to the Gen III maintenance and troubleshooting forum.
  3. spiderman
    spiderman wretched
    7,543
    1,558
    Alaska
    1. Possibly not fully engaging the brake pedal and or not holding it long enough while pressing the power button? The brake switch adjustment is a known issue on the 2010. Do you have a problem disengaging the CC with the brake pedal (jerky)?
    2. If you are not bumping the switches, perhaps the contacts in the switches are corroded causing a false signal?
  4. Former Member 68813
    3,524
    983
    US
    check your 12v battery or the battery connections. When I disconnected mine, I had difficulty putting it in drive the first time.
