electric jack
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by lenjack, Feb 24, 2010.
  1. lenjack
    lenjack Active Member
    804
    114
    Pennsylvania USA
    A couple of months ago, there was a discussion on using an electric jack, such as shown at
    http://www.amazon.com/Buffalo-Tools%C2%AE-Electric-Car-Jack/dp/B000Y343TC/ref=sr_1_1?ie=UTF8&s=automotive&qid=1267066156&sr=8-1-spell
    The question was how good they were and how practical to use. One responder said he was getting one and would let us know, but I have seen no such response. Hoping that person sees this post and will let us know how it worked out.
  2. PriusLewis
    PriusLewis Management Scientist
    1,002
    84
    Denver Metro
    Another easy approach is to use the stock sissor jack and buy a cheap rechargable drill from someplace like Harbor Freight. Set the drill up with socket extension(s) and a socket that fits the jack. Charge the drill and keep it with the jack. This makes quick work of jacking a car, and it is cheap. People with camping trailers that use sissor jacks at the corners do this to make leveling quick and easy.
  3. hobbit
    hobbit Senior Member
    4,089
    468
    Bahstahn
    That's got to be the height of laziness. Most people don't realize
    that it's easy to top up car tires with a hand floor pump, too.
    _H*
  4. mgb4tim
    mgb4tim Noob
    1,153
    111
    Pittsburgh, PA
    I abhor scissor jacks, the tip and wobble way too easily.
  5. LeadingEdgeBoomer
    289
    29
    New Mexico
    Cheap OEM scissor jacks are hard to use on an uneven roadside surface, OK for the garage or driveway. The rechargeable drill idea (#2) is good in concept, but I find that such batteries do not hold a charge very long.
    Still want to hear evaluations of safe jacks for roadside use, electric and manual.
  6. tumbleweed
    tumbleweed Senior Member
    4,067
    690
    Eastern Oregon
  7. mgb4tim
    mgb4tim Noob
    1,153
    111
    Pittsburgh, PA
    +1 for a small hydrolic jack like Weed posted above. I carry one in the truck.
  8. LRKingII
    LRKingII New Member
    679
    132
    Idaho
  9. hobbit
    4,089
    468
    Bahstahn
    The problem with a typical floor jack is if it's sitting on a
    rough surface, when the arm gets a ways up in the air it tries
    to pull sideways and if the jack's wheels don't roll farther in
    to compensate for that, the top pad is trying to pull sideways
    off whatever it's under. If that placement is a little dicey
    to begin with, it could slip off that point and land with the
    weight of the car on someplace more delicate that you didn't
    want to punch upward.
    If someone made a jack with as wide/stable a base as a typical
    hydraulic floor jack, that extends *straight up* without any
    sideways bias, and is designed so you can still get it in next
    to a wheel to safely jack sprung parts of the suspension, I'd
    buy it in a heartbeat. Well, as long as it's not one that needs
    shop air to make work, etc.
    _H*
