Eliminated beep AND gear!!!
Discussion in 'Gen 2 Prius Accessories & Modifications' started by rockvillage, Jun 23, 2011.
  1. rockvillage
    rockvillage New Member
    I just posted this in the maintenance thread as well, but since this resulted from a modification I will put it here as well. Not sure if people frequent one topic but not the other.
    I did the tips for eliminating the reverse beep, but it eliminated the entire gear! No reverse shows up. If I put the car into drive, the R shows on the screen but nothing happens when I select it. I tried repeating the steps, but nothing changed.
    Searching did not find any reference to something like this. I am hoping someone here can help me.
    :eek:
    Anne
  2. macmaster05
    macmaster05 Senor Member
    4,050
    730
    Please clarify - the car will not reverse at all or the R simply does not show up while in reverse?
  3. rockvillage
    It won't go into reverse at all. No reverse camera, no reverse gear - and no beep, so I guess that part worked. :eek:
    Someone on the maintenance thread suggested disconnecting the 12-v battery for 5 minutes to reset everything.
  4. Hal W
    Hal W New Member
    872
    53
    Grand Forks,B.C. Canada
    You could enter the same code you did to eliminate the reverse beep and it may return to the original with the beep! Worth a try. I did this with the door locks but decided to go back to original and it worked by entering the code again. Hal
  5. rockvillage
    It did work. I was just distracted when I checked it!!!
    Thank you!
