Emergency brake pedal
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by newbie, Mar 10, 2009.
  1. newbie
    newbie Junior Member
    24
    Maryland
    Our 2005 Prius emergency brake pedal (rubber part) keeps coming off. Purchased a new one and now that keeps coming off. Anyone else have this problem? Spoke with a friend at work who has the 2004 model and he said yes his came off too, but he never replaced it. What's up with this design?:mad:
  2. magruder
    magruder Average Member
    145
    Colorado
    My 2004 was missing the rubber cover when I purchased it. I haven't thought about replacing it though. Doesn't seem to be a big deal.
    Regards,
    Dave
  3. usbseawolf2000
    usbseawolf2000 HSD PhD
    14,487
    3,001
    Fort Lee, NJ
    My 06 with 90k miles have no issue with the rubber part.
  4. Patrick Wong
    18,210
    6,510
    71K miles on my 2004, parking brake pedal rubber still intact, no problems here.
  5. tochatihu
    tochatihu Senior Member
    9,796
    3,772
    Kunming Yunnan China
    2001 Prius
    clean both parts and glue it on. what the heck. Use mastic, shoe goo, or any of those adhesives with 'deliberately concentrating and inhaling' abuse potential. After that you'll not be troubled again by wandering rubber.
  6. Bob64
    1,540
    93
    Virginia
    a bit of that super-strong epoxy stuff that you mix together will fix it up... just make sure to cover your carpets so you don't get any dripping on it.
  7. ejerommel
    ejerommel Junior Member
    24
    Charlottesville, Virginia
    I just bought a 2005 and it was missing the rubber parking brake pedal cover. Where can I purchase one by mail, I wonder?
  8. Patrick Wong
    18,210
    6,510
    You will need part number 47121-52010 and the MSRP is $4.99 so you'd probably be better off ordering from your local Toyota dealer. The dealers who sell parts via weborder usually have minimum freight charges that encourage you to order a larger $ value.
    If you wish to order several other parts at the same time such as filters etc., I can recommend:
    Champion ToyotaWorld
  9. usbseawolf2000
    14,487
    3,001
    Fort Lee, NJ
    Here is the direct link to the cart. $3.28 plus shipping. To my address in NY, the shipping comes out to $10.50.
    I bought all my maintenance supplies (oil filter, engine air filter, spark plugs, PCV valve, etc.) from them up to 150k miles. I have not ordered brake pads because at this rate, I won't need to replace them!
  10. ejerommel
    24
    Thanks Patrick and usbseawolf2000. I will see if the pedal will stay on my 2005 without glue.
  11. ajgallant
    ajgallant Junior Member
    Mountain View, CA
    I had a similar problem. I solved this by drilling a small hole in the right side of the rubber pedal cover where a catch fits into a small hole in the side of the metal pedal. I inserted a bolt through the new hole and secured it with a nut to the metal pedal. I also used Liquid Nails on the back of the rubber pedal cover. In the past 4 months this has held perfectly.
  12. brick
    brick Active Member
    1,083
    79
    Upstate NY
    Mine fell off last March. I quit trying to fix it when I realized that I don't have a problem operating the parking brake without the rubber part. Looking at the way the rubber clings to the pedal assembly, "by its fingernails", it's no wonder so many of us have lost it.
  13. vstypicals
    vstypicals Junior Member
    28
    Valencia, CA
    CORRECTION: The correct part number for the emergency brake pad is 46252-68010.
