Emergency Shift lock override
Discussion in 'Gen 2 Prius Technical Discussion' started by rkoska, Feb 5, 2007.
  1. rkoska
    rkoska New Member
    16
    I had a problem recently that was caused by a lose conecton in a plug behind the dash that resulted in no power to the start button. The towtruck driver from toyota dealer had to drag the car(with the front wheels locked) on to a flatbed tow truck.We are traveling in Texas and I don't think this dealer has done much service on the Prius. The sevice mgr. said they put the front wheels on dollies to get it in the sevice bay. I was told by a salesman at this dealer All toyotas have a emergecy shift lock override so that the car can be moved off the hiway incase of a 12v power failure. He could not find it on the one Prius they had on the lot.
    He told me it is located under shift knob or behind a popout under the dash on other models.
    Dick
  2. Tideland Prius
    16,402
    <div class='quotetop'>QUOTE(Dick K @ Feb 5 2007, 06:42 AM) [snapback]385501[/snapback]</div>
    Technically what he's saying is true except that they always assume it's been this way and thus tell you there's one in the Prius (like the guy who told me all small cars have 32PSI as their tyre pressure. That's true for Corollas and Civics but not for the Prius).
    Unfortunately, you'll have to dolly the front wheels or use a flatbed truck. When the Prius is switched off, it's automatically put into P (You don't have to press P before turning the Prius off).
  3. rkoska
    rkoska New Member
    16
    <div class='quotetop'>QUOTE(Tideland Prius @ Feb 5 2007, 01:39 PM) [snapback]385611[/snapback]</div>
    So is the Prius the only Toyota that does not have the Emergencey shift lock overried.? :eek:
  4. jayman
    jayman Senior Member
    13,439
    641
    Winnipeg Manitoba
    I was under the impession the parking pawl is actuated by a 12 vdc solenoid. Seems to me, if that's the case, once the 12 vdc system goes dead, you're SOL
  5. tochatihu
    tochatihu Senior Member
    9,457
    3,655
    Kunming Yunnan China
    2001 Prius
    The classic Prius does indeed have a shift lock override button. No info here on how the new model is set up.
  6. jayman
    13,439
    641
    Winnipeg Manitoba
    I checked the manual for my 2004, and there is no mention of any emergency shift lock override. With the parking pawl activated electrically, I really don't see how you could disable it with the 12 vdc battery dead.
  7. galaxee
    galaxee mostly benevolent
    9,810
    468
    MD
    no. there is no way to get the car out of park if the battery's dead and won't take a charge.
    the park lock mechanism is buried. techs at the shop have speculated that you could get up in there and remove the park lock mechanism and the car would freewheel, but then you've got that electricity generated and nowhere to go because the hybrid battery relays are open.
    and then there's actually getting under the car to even do this...
    this is the same reason that they say not to tow a prius with the front wheels on the ground.
    so no. the 2nd gen prius does not have a way to do this, you pretty much have to stick it on dollies.
    *please please please please* complain loudly about this! it drives the techs crazy. hence the speculation of a way around it...
  8. Bill Merchant
    Bill Merchant absit invidia
    4,096
    85
    I think the echos of the complaints may have been heard; the Camry Hybrid has a park override.
  9. rkoska
    rkoska New Member
    16
    In my case it was a loose wire behind the dash that caused the loss of ignition. I was very lucky that this happened as I shut the car off at home. I was also lucky to have it towed by a Toyota dealer truck that came to my location with plastic slide chocks to place under the front wheels. I shudder to think of what would have happened to our Prius, had this happend on a freeway. We love our Prius, But will not buy another until this is corrected. :angry: Something so simple to correct should be a MFG. safety recall.
    Dick
  10. jayman
    13,439
    641
    Winnipeg Manitoba
    <div class='quotetop'>QUOTE(galaxee @ Feb 10 2007, 12:23 AM) [snapback]387861[/snapback]</div>
    This doesn't sound like a simple fix but rather a re-engineering. So it looks like we're stuck with it.
    Got to thinking about my co-workers 2006 Range Rover HSE. Last summer we were at my hobby farm and I was really interested in how everything worked. There is a huge owner manual and a bunch of supplements.
    I recall the fuel door release being electric, but if the battery were dead or the release failed, there was a backup method: remove a small trim piece and use a manual cable pull system.
    When you consider how often those things need gas, that might come in real handy!
  11. jendbbay
    jendbbay Member
    223
    <div class='quotetop'>QUOTE(galaxee @ Feb 9 2007, 11:23 PM) [snapback]387861[/snapback]</div>
    I'm pretty freaked out about this issue. Is there no provisions we Prius owners can make for this eventuality? I'm worried about moving the Prius a short distance in an emergency, say off the road or something, and I'm worried about how to get it going again, if its small battery dies. What about tow truck bringing a quick charger such as they bring for regular car's regular batteries? Is this not workable? Why the need to have dollies and all if its just a dead, small battery?
  12. rkoska
    rkoska New Member
    16
    In my case ,nothing wrong with the 12v battery. I had no ignition. A simple momentary switch (as other Toyotas have) Under the hood or on the lower dash to apply 12v to park pawl selanoid. It could even be a mechanical release like the hood latch.
    Dick
  13. Beryl Octet
    Beryl Octet New Member
    1,293
    Abingdon VA
    <div class='quotetop'>QUOTE(jendbbay @ Feb 12 2007, 12:31 AM) [snapback]388756[/snapback]</div>
    Yes, a tow truck would be able to jump start a dead 12V, assuming it's not internally shorted or something. It does perhaps seem shortsighted not to have some mechanical shift override, but how often would it need to be used in all actuality?
  14. hill
    8,564
    Our Lexus SUV hybrid 400h has 'N' so I suppose the Highlander has the same. We CAN put it into 'N' with the ignition not on, and it can be pushed. Evidently it IS possible to have the Toyota line of hybrid cars freewheel .... right?
  15. Beryl Octet
    1,293
    Abingdon VA
    <div class='quotetop'>QUOTE(hill @ Feb 12 2007, 12:45 PM) [snapback]388940[/snapback]</div>
    Apparently not. If you can't get enough stuff booted up to get it into neutral, then you are stuck... I think this very case happened to someone, and the car was stuck in the garage until someone with jacks and wheel dollies shows up (what you want) or the tow truck drags it (what you don't want). There is also concern if it breaks down on the road with some sort of computer failure. I think those cases are rare, but in the "could possibly happen" category. If the Prius is turned on and in neutral, then you can push it off the road or whatever. If it's in neutral and turned off, however, then it puts itself in park. Maybe the Lexus is different?
  16. galaxee
    9,810
    468
    MD
    the prius is the only one with this particular issue. the rest of the hybrids are fine to go into N with a dead 12v battery.
  17. Bill Merchant
    4,096
    85
    I don't understand all this worry. All four tires could explode and you'd be stranded. You could run out of gas and try to drive on electric until you fried the HV battery. You could lose all coolant and melt the ICE.
    It COULD happen! I'm not too worried.
    On the other hand, I could leave my car unlocked with the windows rolled down and walk away and feel pretty sure no one could roll it away. Some yahoos once rolled my (original) VW Bug into a ditch for me, just for fun, I guess.
  18. qbee42
    qbee42 My other car is a boat
    18,058
    3,076
    Northern Michigan
    <div class='quotetop'>QUOTE(Bill Merchant @ Feb 14 2007, 02:07 AM) [snapback]390060[/snapback]</div>
    Bill, these are my feelings exactly. An override is a reasonable idea, but the lack of one causes me no anxiety whatsoever. Having a control surface fall off of an airplane, now that worries me.
    Tom
  19. ilusnforc
    ilusnforc Member
    404
    San Antonio, TX
    I believe the reason for no emergency shift lock override on a 2nd gen Prius is that they have electronic actuated shifting mechanisms. All other cars mentioned, Toyotas and the Hybrid Camry, have mechanical linkages that physically connect to the transmission and the override simply allows that linkage to put the transmission into neutral and disengage the parking mechanism. The Prius uses a CVT with only one physical gear, forward, and that can variate it's ratio so there was no need to use mechanical linkages because from my understanding all the Prius would have to do is engage or disengage a parking mechanism, and in "Reverse" it would simply allow electric power only and turn the electric motor backwards for reverse (the ICE can't rotate backwards). So really, if there was a way to reach down by the CVT somewhere with a pair of pliers and pull on the actuator that locks the drivetrain in park, it should freewheel, I think... assuming that there is anything to grab and pull on. It would probably be best to ask a tow truck to bring wheel dolly's to move the car though.
  20. hill
    8,564
    <div class='quotetop'>QUOTE(jayman @ Feb 12 2007, 01:17 AM) [snapback]388749[/snapback]</div>
    Consumer reports year after year continually slams the RR for being high maint costs and low on reliability. THAT's why we traded ous in for the hybrid lexus SUV - 400h. Our RR was frequently in the shop, and the shop was ALWAYs over filled ... sometimes requiring us to leave the car there, for WEEKS at a time. If our 400h EVER has to go into the shop they tell me we will get a 400h to use in its place. The RR? Heck, we'd have to take what ever rental that might be available, whether it be a compact, a pick up, a mini van ... a real pot pori. Electric gas door? Hardly made the dang thing worth $60k IMHO.
    Good ridence
    <div class='quotetop'>QUOTE(ilusnforc @ Feb 14 2007, 01:42 PM) [snapback]390241[/snapback]</div>
    Our 400h (and I believe the highlander too) has CVT. Maybe a better theory is in order.
