Engine Cranking Obstacle
Discussion in 'Gen 2 Prius Technical Discussion' started by john_dough, Sep 7, 2008.
  1. john_dough
    john_dough New Member
    75
    From what I know about engines (not much!) they take some time to start (crank). How does the Prius achieve almost instant starting of the engine, sometimes many times per minute? Also, I thought that engines are wasteful of fuel and battery power during the startup crank.
  2. hobbit
    hobbit Senior Member
    4,089
    468
    Bahstahn
    Only when they're cold, really. When they're already warm and
    optimally repositioned for fairly instant light-off [as the
    hybrid controller indeed does with the ICE as it's brought to
    a standstill], there's no appreciable overhead in a restart. There's
    a short burst of battery current to spin it, injection begins,
    and off you go.
    _H*
  3. Patrick Wong
    18,200
    6,491
    A regular gasoline engine uses a small electric motor to start the engine. The motor can rotate the engine at only around 300 rpm or so. That small starter motor makes plenty of noise so it is obvious when it is running.
    Prius uses one of two motor generators located in the transaxle to start the gasoline engine. The motor generator can produce much greater power and torque (compared to the little electric motor used as a starter motor in regular cars) and will spin the gasoline engine at ~1,000 rpm. Further, the motor generator does not make much noise, so it is not always obvious when the gasoline engine starts.
  4. David Beale
    David Beale Senior Member
    5,963
    1,985
    Edmonton Alberta
    Further, the motor generator is always "engaged" with the engine. So you don't have a solenoid to fire. There are no gears to shift around. The Prius uses "magnetics" to engage/disengage various "power paths" in the HSD. This is also how the "CVT" works, though personally I don't like the use of that term. It evokes images of cones and steel belts in most peoples minds, when in actuality, we don't have those in a Prius.
  5. john_dough
    75
    Makes sense--thanks for the replys.
