Engine Idling during cold weather--info cards?
Discussion in 'Environmental Discussion' started by efusco, Nov 6, 2008.
  1. efusco
    efusco Moderator Emeritus
    19,891
    1,194
    Nixa, MO
    For whatever reason I've noticed that people are leaving their cars idling more as the temps start to cool (it is no where near "cold" yet)...I've noticed it mostly at my kids' daycare where they're inside for 5-10 minutes to drop kids off and it's a fairly safe area (Church parking lot).
    So, I'm wondering if anyone knows of any friendly, informative info cards that one can print off telling the negative things about idling one's car...how much CO2 is released annually, how much gas burned, etc. Something I could leave on people's car without upsetting anyone but rather informing them so they at least idle their car knowing the negatives.
  2. jayman
    jayman Senior Member
    13,439
    641
    Winnipeg Manitoba
    Evan
    Honestly, I think you're wasting your time. Most folks are simply too brain dead to even give a s***.
    Yes, I understand this is frustrating, waste of resources, bad for environment, bad for the actual MOTOR, etc. Until strict anti-idle laws are passed, not going to happen
    I was at a carwash last winter and this fool in a Dodge Ram Cummins pulled into the stall next to me. He left that thing idling and I was damn near getting gassed by it. SO I finally walked around to his stall and told him to turn it the f*** off.
    The guy was a scrawny little thing. He claimed it was "bad" for the motor to turn it off. I told him it would be bad for his rectum if I shoved the wash wand up his nice person and turned it on
    He turned the motor off
    jay
  3. FreshAir
    FreshAir New Member
    The Redwoods
    Jerry I like your persuasive attitude, rude as it may be perceived. Evan I think a line about personal $$$ cost at 10min/dayX5 daysX# of school days may be as persuasive as nebulous costs to the environment.
  4. efusco
    19,891
    1,194
    Nixa, MO
    I realize it's probably a waste of time...but it'll make me feel better.
    I take it nobody's seen anything online that covers this stuff....
  5. Fibb222
    Fibb222 New Member
    1,499
    99
    I made a word doc for that purpose once. I'll try to find it if I get a chance....
  6. qbee42
    qbee42 My other car is a boat
    18,058
    3,076
    Northern Michigan
    Evan, perhaps you could make some note-holders out of potatoes. If you get the correct size, they fit snugly in the end of an exhaust pipe. That way you don't have to worry about them blowing away in the wind, and there is a better than even chance that they will be noticed. :D
    Tom
  7. SSimon
    SSimon Active Member
    1,426
    N/W of Chicago
    Here's something a little more diplomatic than Tom's and Jay's approach....
    Idling Your Car
    There are sites that address the consequences more comprehensively however I think this sums things up well enough and anything longer than one page without bullet points would probably be ignored. I also think people will respond better to potential costs saved by them (i.e. fuel costs saved and avoiding damage to their car) than they would about CO2 and the link hits on those points.
    Lots 'o luck. I, too, believe you're fighting an uphill battle but how very noble of you.
    I just thought of something. I leave my car idle at times when running quickly into a store where I can keep an eye on it. Sometimes I'll be in there for about 10 minutes as well. I do this to keep the engine warm so that I don't revert back to that dreaded 25 MPG 5 minute segment when getting back in my car but does idling drain the battery to the extent that the ICE will have to recharge it thereby netting no benefit?
  8. Fibb222
    Fibb222 New Member
    1,499
    99
    no luck, couldn't find it. But this might help Idle Free BC | Resources
  9. JimN
    JimN Let the games begin!
    7,028
    1,116
    South Jersey
    No. I do it all the time and the only ill effect I've noticed is that trips to the gas station are less frequent.
  10. efusco
    19,891
    1,194
    Nixa, MO
    Good link.
  11. efusco
    19,891
    1,194
    Nixa, MO
  12. RobH
    RobH Senior Member
    2,369
    984
    70
    Sunnyvale, California
    My car turns itself off when the engine isn't needed. It even does that at stoplights.:)
  13. bac
    bac Active Member
    863
    52
    Pennsylvania
    If it makes you feel better, please go with either of those cards. You are certainly correct in your line of thinking, and if anyone at all would respond, it would make a difference. Now ..... will it help? Sadly, the simple answer is "no-no-no". The vast majority of drivers in America won't even check their tire pressure, let alone cut the engine when it's cold outside.
    Moreover, where I live, it would almost certainly lead to the vandalism of my Prius. Again, sad ...... but oh so true.
    ... Brad
  14. tripp
    tripp Which it's a 'ybrid, ain't it?
    4,717
    79
    Denver, CO
    Evan, just photoshop it. The only metric in there is the 4.5 l/hr bit. The rest looks like it'll work fine. You might get rid of the BC references too, but it would be easy to touch it up.
  15. efusco
    19,891
    1,194
    Nixa, MO
    Clearly you have appreciation for how lazy....er, that is busy I am.
    Yea, I may do that actually, just a matter of finding the hours and motivation and having those two rare items align properly.
  16. priapus08
    priapus08 New Member
    Colorado
    :eek: How is the response to the card?
    I noticed you may be in the "show me" state. I was in that state of mind once here in Colorado
    We are all familiar with the old saw that "actions speak louder then words" (so why waste paper?).
    I suggest therefore after you have your kids safely inside, simply take the last car left running by anyone, (owner inside building with no view of you, and no passengers inside) Drive it a reasonable distance depending on your commitment to physical fitness, and safely park, and lock it.
    Return the keys to the office and let them know you found them near their building and thought someone might be looking for them. If you are caught in the act (I was not), tell them someone told to you move the car(that would be me), but you are not sure why, now that it caused so much trouble. ;)
    If you are lucky the owner will already be spreading the word that they "left their car running and it disappeared" before you even get back as happened for me.
    I am not sure how often you will need to repeat this feat to sufficiently spread the knowledge that it is not a reasonable risk to leave a car running unattended. (it is against the law to leave a vehicle running unattended here, but occurs frequently with little enforcement)
    In the meantime you will provide a self propagating community service announcement, and get some exercise.
    This advice must be followed at your own risk. It is illegal to "joy ride" in Colorado but it is required to lend assistance including moving vehicles other then your own when there is a hazard. I suspect environmental hazard is not what they had in mind when the law was written, but these are modern times, with modern hazards.:rolleyes:
    I did this once, and it worked for about 4 months at a local elementary school. I was unwilling to reinforce the original message later. They assigned one of crosswalk attendants with a cell phone to watch the running cars. (Can you believe their solution? No Parent Left Behind the wheel!)
  17. efusco
    19,891
    1,194
    Nixa, MO
    Ok, I bit the bullet....
    I edited the image/card above to get rid of the words "Our fleed is" and the BC references and that graphic. Printed out 4 copies per page on card stock.
    On the back of each of those is the info link (Idling Your Car). The text is pretty small, bit if I get anyone's attention maybe they'll bother to read it....who knows.
    8 copies printed, hopefully I don't get beaten up!
  18. efusco
    19,891
    1,194
    Nixa, MO
    See my prior post...will start putting the cards on cars this week I guess.
    I'm thinking that grand-theft auto is probably not a good idea for a local physician and may have some serious adverse consequences for me! I like the concept though and it would likely have much broader impact.
    That said, I figure people wouldn't get the idea that it was about idling the car and would just start leaving the car running and locking it from the outside.
  19. DaGeek
    DaGeek New Member
    48
    So what's next? Do you also think you somehow have the right to waltz in to my house and turn down my thermostat because you deem that an evironmental hazzard also???
  20. effwitt
    effwitt Paparazzi Magnet
    225
    Eagan, MN
    Since it's a church parking lot you could take the WWJD approach - Jesus wouldn't leave his Hummer idling, wasting fuel and polluting the environment.
    Are there any real nice cars idling in that parking lot? If so, where is it? Christmas is just around the corner and I'd bet mom would like a low-mileage Lexus as a present.
